Maximum degree of side angle
Posted: Mon Jun 20, 2005 8:23 pm
by TiredIronGRB
What is the maximum degree of side angle for the C30X vehicles?
George
Side angle specs
Posted: Thu Aug 04, 2005 6:04 am
by Roy Gardiner
In the C303 manual specs it says "40%" George - which I guess equates to approximately 40 degrees as a percentage of horizontal!
No doubt taller tyres will reduce that a bit - how about : a side-slope, a big tree, a good rope and a big protractor....then you can let us all know for real!
Roy
Posted: Thu Aug 04, 2005 7:55 am
by TiredIronGRB
I've had it at 40 degrees this weekend...
Tilting Vehicles
Posted: Thu Aug 04, 2005 9:04 am
by Roy Gardiner
I reckon that's probably around 30 degrees George (I build tilting vehicles for a living) which probably felt scary enough - anything over 40 degrees is very, very scary at low speeds (my vehicle's pulling 1.2G when it gets to that angle) although London buses tilt to 45 degrees before they go over as I recall - Dennis has probably tried it!
Did you get it to lift any wheels? Last time I drove a 712 we had the front waggling a paw, backside buried in a gully (wet clay) - time to run the winch out...
Roy
Posted: Thu Aug 04, 2005 9:59 am
by TiredIronGRB
I have a inclinemeter on the dash and in two spots it was at 40, I think in that shot it was a little over 30.
Posted: Thu Aug 04, 2005 10:02 pm
by lindenengineering
Hey Roy and the readers
About 20 years ago I was involved in a sale of 10 Leyland Olympian Eastern coachwork bodied double decker coaches to Gray Line of San Francisco. One of those units actually did the tilt test to 51.5 degrees before falling.
Once in service I was given the boring job of accompany the units on their trips with passengers. On one memorable trip scudding under the trees at 14'6" above the ground in Muir Woods, this lady passenger with a Georgia Southern Belle accent enquired "excuse me sir, but do these buses turn over easy"?
No, I replied with a straight face they all have to pass the "BS" test,(some passengers got the double entendre immediatly judging by the smiles on their faces) pointing to a UK safety kite mark. See, it looks like a kite but actually is a layed over "B" on top of a triangle with an "S" snaking through the middle of the triangle. IT'S A BRITISH SAFETY APPROVED BUS!
So I continued to announce in a stern voice "As you can see this actual bus was tilted to 43 degrees before it tipped over. Every bus has to pass this British Standard test. There was a pause in the passenger compliment some were clearly impressed.
Then I blurted out "So did the Titanic and look what happened to that thing"!
Result was side splitting laughter on the top deck that caused some lower deck passengers to come up to see what was all the excitement.
Posted: Fri Aug 19, 2005 8:41 am
by limpan4all
In the Swedish military manual the following information is printed. For C303 (TGB11) incline is specified to 80% or 39 degres, sidways under driving 40% or 22 degre, C306 (TBG13) incline 60% or 31 degre resp 40% or 22 degre sideways.
Tilt testing the 1314
Posted: Mon Sep 26, 2005 4:28 am
by Roy Gardiner
Took the 1314 out yesterday to an offroad day down in Somerset.
I can now confirm that it handles 30 degree sideslopes happily...more so than the driver maybe!
The old girl went very well through deep (over 1 ft deep) rutted mud, 3ft of water (with a solid base) and inclines/drop-offs over 30 degrees and didn't object to me lifting the rearmost axle a couple of times.
The pneumatic difflock engage/diengage works beautifully - even produce a sigh of relief when you disengage them!
Pictures to follow when I receive them folks...
Equally importantly it averaged 50 mph (about 12mpg UK) for the 200 mile round trip, though that mechanical fan HAS to go. Taller (modern) tyres will quieten the cab at cruising speed too.
Roy
