Filters, parts and consumables thread.
Posted: Sun Nov 17, 2019 2:07 pm
Good day to all.
I am starting to a mass parts to refresh and restore my tgb 11. I have found some information across the pond on c303.de and from the now disbanded yahoo group. I thought it may be nice to update and share information about parts sourcing to help others find quality parts cheap. Obviously the two big sources are Tatanka and what you can find at your local auto parts store. There are lots of other locations to find parts with varying quality and maybe we can help each other sort where to purchase.
For example the element for the Filter king pressure regulator/ filter seems to not be available in the US. I have a part number FK67E, but I have had trouble sourcing it outside the UK. There is a great resource listed below I found buried in a brake parts thread which lists most of the parts. Unfortunately many are unverified, perhaps we can bring this list up to a more current form and build upon it. I will try to update and keep it current as I go through my process. Hopefully we can add our experiences and help each other get the best parts locally for a good price! I started out with the fuel filter/ regulator unit 99901.419 and found the element FK67E as the filter alone. I am chasing it around Europe but hope to find a cross reference in the states. Working on the best CV boot source too! I have taken to adding to the below list for reference.
I am also looking for a good source for a carburetor rebuild kit, I am fairly certain Stromberg 175 cd-2se carbs were used in all trucks built and high quality rebuild kits are easier to find in the UK.
Cheers!
Cheers!
Klug wrote: Mon Sep 19, 2016 6:29 am This page?
http://www.angelfire.com/extreme3/sgrig ... aneous.htm
In order to keep a copy in this forum, here's the cross-references parts.Code: Select all
Part Name Part Manufacturer Part Number Other Vehicles used in Original/ Replace/ Improve/ Accessory Comments Cost (Country) Air Filter Volvo 681609 Air Filter Beck/Arnley 042-1355 Replace VERIFIED (USA) / Advance Auto Parts Air Filter NAPA FIL2170 Replace Gold quality (VERIFIED) $8.50 (US)/NAPA Air Filter NAPA SFI 22170 Replace Silver quality VERIFIED $5.49 (US) / NAPA Axle Boot Volvo 1563012 Original Group E-Mail from Brian Steen Axle Boot Brake reservoir cap Volvo 1272107 (product # 236298-001) Replace Oil Filter Fram PH7328 Volvo 164 Replace VERIFIED $4.18 (US) Oil Filter Pennzoil PZ104 Replace Not Verified Yet $3.59 (US) Oil Filter Purolator L14670 Volvo 164 Replace VERIFIED $2.88 (US) Oil Filter Purolator PL14670 Volvo 164 Replace VERIFIED $5.88 (US) Oil Filter K&N HP1009 Replace Gold Quality (Not Verified) $9.98 (US) Oil Filter Advance Auto Parts AA16 Replace Not Verified Yet $2.48 (US) Oil Filter Beck Arnley 0418145 Replace Not Verified Yet $10.99 (US) Oil Filter Mann W917 Spark Plug Wire Set Autolite 86100 Replace VERIFIED (Attaches to screw-on cap\, not screw threads) $21.99 (US) Spark Plug Wire Set Xact 6050 Replace Not Verified Yet $15.99 (US) Spark Plug Wire Set Beck Arnley 1752336 Replace Not Verified Yet $15.99 (US) Spark Plug Wire Set Bosch 09021 Replace Not Verified Yet $18.99 (US) Spark Plug Wire Set Standard 9638 Replace Not Verified Yet $22.99 (US) Spark Plug Wire Set Mileage Plus MP W2610 Replace Not Verified yet $14.99 (US) / NAPA Spark Plug Wire Set NAPA (Belden) BEL700165 Replace Not Verified Yet $19.99 (US) Sparkplug A/C R43F3 Replace Not Verified Yet Sparkplug Bosch W6BC Original Sparkplug Bosch 4232 Replace Not Verified Yet Sparkplug NGK 4085 Replace Not Verified Yet Sparkplug Autolite 275 Replace VERIFIED (0.028 Gap) Sparkplug Champion 929 Replace Not Verified Yet Distributor Cap Bosch 1 235 522 053 1973/1974 Capri 2600 / 2800 Original Distributor Cap Mileage Plus Electrical EP406SB Replace VERIFIED $5.99 (US) / NAPA Distributor Cap Beck/Arnley 1742741 Replace Not Verified Yet $13.49 (US) Distributor Cap GP Sorenson 225015 Replace Distributor #0 237 300 001 VERIFIED $12.29 (US) / Advance Auto Parts Distributor Cap Bosch 03008 Replace Not Verified Yet $16.99 (US) Distributor Cap Niehoff FF60H Replace Not Verified Yet $7.49 (US) Distributor Cap Echlin EP406 Possibly Porsche 911 Turbo Distributor Rotor GP Sorensen 235113 Replace VERIFIED $8.69 (US) / Advance Auto Parts Distributor Rotor AC Delco F403 Replace Not Verified Yet $5.49 (US) Distributor Rotor Bosch 04017 Replace Not Verified Yet Distributor Rotor Bosch 1 234 332 173 Original VERIFIED $13.69 (US) / NAPA Distributor Rotor Echlin ECH EP407 Replace VERIFIED $6.49 (US) / NAPA Distributor Rotor Beck/Arnley 173-7527 Replace VERIFIED $7.99(USA) / Advance Auto Parts Distributor Condenser Bosch 1 237 330 273 Replace Not Verified Yet Points Bosch 1 237 013 078 Original Not Verified Yet Distributor Bosch 0 231-303-058 original Fuel Filter (Rear) Fram G2 Replace VERIFIED - out of fuel tank $2.50(US) / Wal-Mart Fuel filter/ pressure regulator Filter King 99901.419 Replace From Pierce Manifolds 408-842-6667 or 800-874-3728 $ 60.00 US Fuel Filter Element Filter King FK67E Replace Dellortoshop.com 12.95 (US) Lower radiator hose NAPA NBH 8207 REPLACE 2 pieces are needed Verified $13.69 (us)" Vacuum lines for lockers Gates NBH H-190 REPLACE Verified$3.09 / 6ft (us)" Thermostat NAPA THM 238 Volvo 164 Replace Needs a gasket (THM 1070)Verified $6.99 (us)" Thermostat gasket n/a THM 1070 Volvo 164 Replace Verified $1.09 (us) Relay 24v N. O. Hella 003510141 replace It will replace Bosch relay 24v N.O. $32.00 us" Relay 24v N. C. Hella H41388501 replace It will replace Bosch relay 24v N.C. $32.00 us" Front brake flex line Precise Lines 571.106 #106 Volvo 1800/122 Improve stainless steel IPD p/n PL 671799 Fan V belt NAPA XL25-7350 Replace 25/64 x 35-5/8 9.5/10mm x 905mm "NAPA" Fan V belt Volvo 930282 IMP 7179 Original 9.5mm x 888L Brake shoes-front Land Rover RTC 3424 LR series II 109 SW w/ 2.6L petrol 1971 replace Brake shoes-rear Land Rover STC 2797 LR Series II 109 SW w/ 2.6L petrol 1971 replace Wheel cylinder-right rear Land Rover 243296 LR Series II 109 SW w/ 2.6L Petrol 1971 replace Wheel cylinder-left rear Land Rover 243297 LR Series II 109 SW w/ 2.6L petrol 1971 replace Wheel cylinder front left Girling (Lucas\, Lockheed) 600200 Land Rover Series 109 LWB 6 cylinders Replace Verified $140 CND per pair Wheel Cylinder front right Girling (Lucas\, Lockheed) 600201 Land Rover Series 109 LWB 6 cylinders Replace Verified $140 CND per pair Door handle Volvo 64321 IMP Original Dashboard warning lamp Sylvania 3797 osram 13913 Philips 13913 model is replaced by 3797 Osram (at www.topbulb.com) $1.50 (US) Radiator cap Volvo 461646 B18/B20 1967-73 original Clutch casing drain plug Watts/Anderson-Barrows Metal Corporation A-710/PB109 Replace 1/8 NPT plug-square head brass replaces original steel plug) $0.92 Lowe's Home improvement Valve Cover Gasket Felpro VS26067 Volvo 164 Replace VERIFIED $12.49 (US) Valve Cover Gasket Beck Arnley 0360750 Volvo 164 Replace Not Verified Yet $9.59 (US) Upper Radiator Hose Volvo 644132 Original Windshield Wipers Blades Trico 18-1 n/a Replace VERIFIED
