Fire coming out of tail pipe
Posted: Fri Aug 06, 2021 7:51 pm
by JimmyC
I noticed some fire coming out of my tailpipe this evening. I was coming down a long steep hill, engine braking the whole way. About 5 minutes in I noticed some orange light in my mirror. It was fire coming out of my tailpipe. If I cracked the throttle just a little it went out. The truck runs fine. I have never seen this before and wondering if anybody else has. I am guessing one cylinder is not firing in that condition.
Re: Fire coming out of tail pipe
Posted: Sat Aug 07, 2021 12:15 am
by boeing7873
Mine does it all the time. The bangs a are quite loud too. The problem is that air is coming in somewhere near the exhaust manifold and unburnt gas from the idle jets/idle screws re-ignites down the exhaust.
I have not been able to lean it enough to avoid it, but if I fix all holes in the exhaust system, it goes away. My problem is in the flexible union between manifold and heater.
Lately, I just turn the ignition off on long downhill runs. The idle valves close and all the backfiring stops.
Posted: Sat Aug 07, 2021 5:08 am
by JimmyC
I have always wondered if it was possible to rig up something to shut the idle valves during engine braking. I thought doing so might help with the stench. I will look for some exhaust leaks
Posted: Sat Aug 07, 2021 9:57 am
by boeing7873
The idle screws make a small difference, but I run into a dead power zone between 1000 and 1500 rpm. I believe this is due to small vacuum leaks. The last one I found was from the gaskets of the choke plates.
Smoking the manifold and carbs to look for leaks is very important.
Posted: Sun Aug 08, 2021 10:03 am
by lifefloat
I've been having some backfire issues lately as well. I bring this up in reference to what boeing7873 mentioned as I too have some leakage where the exhaust header pipe mates up to the flexible union. I am kinda suspecting this may be contributing to my issue.
I'm probably going to disassemble the SAV supplied clamps at this spot and see if there is any way I can improve the connection at that point.
Anybody have any suggestions as to a better clamp at this spot?
Posted: Sun Aug 08, 2021 10:33 pm
by boeing7873
The ideal solution is a true flexible connection between the manifold and the heater intake. SAV sells a kit, quite expensive, but looks good. I have not tried it as I find it quite expensive. I welded two short flexible connections bought at the local store and I believe they are too rigid. No clamp will solve the problem. Flexibility is the key.
Posted: Mon Aug 09, 2021 11:57 am
by Jim LaGuardia
Change clamps to t-bolt full radius type. I find that these work best. Never weld any couplings to header pipes. It complicates future repairs.
Posted: Tue Aug 10, 2021 5:02 am
by lifefloat
Thx for the tip on the T-Bolts Jim. And as a bonus they are stainless steel...............winner
Posted: Wed Aug 11, 2021 7:14 am
by boeing7873
Jim LaGuardia wrote: Mon Aug 09, 2021 11:57 am
Totally agree with Jim. When I meant welding, I was referring to the flexible adaptors to the plates bolted to the heater side. And good clamps are a must but only after you figure out the flexible segments. Something needs to move or something will break.
