Air tunnel insulation
jan.bauwmans
Post by jan.bauwmans »
I still have the foam inside the air tunnel. It's fixed with steel clips. Is it not better to remove it ? Afraid there is rust building up underneath. What is the purpose of this foam? Noise reduction or dust catcher ? Image
Verstuurd vanaf mijn SM-G998B met Tapatalk
Re: Air tunnel insulation
Insulation both temp and noise.
I removed mine from the 712 as it was in terrible shape.
It was fairly easy to remove using a Heat Gun, spatula, and some patience.
I ended up applying a Noise deadening material that you can roll on or brush
apply, takes several applications to get a 4mm to 5mm overall thickness. This
product has rust inhibitors, is high temp, and water proof. It's a Polymer base.
My wind tunnel ended up rust free.
Here's a link to the product I used as an FYI
https://www.secondskinaudio.com/sound-d ... rum-liquid
ChickenPinz
Post by ChickenPinz »
Does anyone know if there's a replacement material for the original that's closer to the foam type material?
710K
whitesik
Post by whitesik »
I used 1/2" Dynaliner and it worked very well. I made cardboard templates to get the correct sizes for the pieces before applying it.
https://www.dynamat.com/products/dynaliner/
75 Swiss 710K
W9YG
