Maloya tires
Posted: Sun Jul 17, 2022 6:51 pm
by satosh
So I have my original maloya tires on my 6x6 and to replace all six is 2.5-3k for the coopers I want. Given that cost can someone tell me exactly why I NEED to replace them asap even though they are in good shape very minimal rot if any. Hold air great good amount of tread left too. I see everyone saying replace asap but no one saying exactly why. Thanks
Re: Maloya tires
Posted: Sun Jul 17, 2022 9:30 pm
by ChickenPinz
From what I read, if you drive on rain, ice, or packed-snow roads, the Maloyas are on the scary side.
Re: Maloya tires
Posted: Mon Jul 18, 2022 7:18 am
by Stumbler
There's nothing wrong with 98% of each one of your tires. You just don't know where the 2% is, and it doesn't say and it gives you no warning when it gives out. That 2% is pretty important. (It's usually about the size of a hole or crack)
Re: Maloya tires
Posted: Sun Jul 24, 2022 4:31 pm
by David Dunn
Unless you plan to use rocky off-road, on a farm, and never see a highway, the Maloyas are only "ok". They are an extremely old technology tire that went away over 40 years ago. Like NDT tires, they are hard as rocks and have little traction on wet slippery paved road. I've had 4 Pinzes in 21 years. My 710 had the Maloyas for a few weeks, my 712 had them for 1 day. The first day I had my 712 I had it on a wet sweeping freeway transition when I determined that they are a democratic tire on a 712 and voted 4 to 2 to go straight and it required extra coaxing to get them to follow the road. I put BFG's on both ( though there's are numerous good tires). My 716 was a Swedish municipal truck with Coopers. My current 718K came from ATL with BFG MTs which was the standard tire for them (285/75 but on wider rims)
People seem to think of Maloyas as the "Pinz" tire, but in fact the Maloyas were only on Swiss contract Pinzgauers, which made up roughly 1/3 of the total gas Pinzes manufactured, and Maloya is a Swiss tire manufactuer, hence is why they were used. Unless specified otherwise by contract the standard tire supplied by SDP would have been Semperit 235/85 tires.
255/85 is a good choice of a tire with a little extra height for a improved road speed. 285/75 are the same height but are a bit too wide for the rims and extra muscles needed to steer ( and 255s can easily be aired down for the same footprint and airing down 285s greatly increases your chances to roll off the rims)
Re: Maloya tires
Posted: Tue Jul 26, 2022 10:24 am
by ChickenPinz
I keep the Maloyas for when I want to have a classic parade look for the truck.
For driving, though, I went with Falken Wildpeak MT01 LT255/85R16. After much research, I found (as others have) that this is the sweet-spot size.
Re: Maloya tires
Posted: Mon Aug 22, 2022 2:57 pm
by BobV
Hi ChickenPinz,
Can the Falken's be mounted to the stock rims or do you need the Ford transits?
Bob V 710k
Re: Maloya tires
Posted: Mon Aug 22, 2022 6:19 pm
by ChickenPinz
LT255/85R16 tires can be mounted on the stock wheels (rims). Note that the rim design does not have the bead retaining ridge.
They are like the bottom profile (pictured below), whereas most modern rims are of the upper profile.
- US4606390-drawings-page-2.png (51.18 KiB) Viewed 12354 times
Re: Maloya tires
Posted: Tue Aug 23, 2022 9:01 am
by BobV
Thanks for your response & information. I'm looking into going with the transit rims. They seem affordable & readily available. Also receiving a lot of Pinz owner endorsements. Great to have your tire endorsement as well.
Best.....Bob V 710k
Re: Maloya tires
Posted: Fri Aug 26, 2022 11:52 am
by jan.bauwmans
I have the Falken Wildpeaks on the stock rims with inner tires and fits perfectly !
Verstuurd vanaf mijn SM-G998B met Tapatalk
Re: Maloya tires
Posted: Fri Aug 26, 2022 1:16 pm
by ChickenPinz
jan.bauwmans wrote: Fri Aug 26, 2022 11:52 am
Are you saying you put tubes in these tubeless tires?
Re: Maloya tires
Posted: Sat Aug 27, 2022 8:21 am
by jan.bauwmans
Yes indeed and on the original rims
