Tachometer with hourmeter
Posted: Thu Jun 01, 2023 12:24 pm
by ChickenPinz
Has anyone found a tachometer with hourmeter that will fit (same hole size) in the hole to the right of the fuel gauge? Mine has just an hourmeter there at present.
Something like in the below picture, but a tach not a clock.
- pinz dash with tach maybe.jpg (157.91 KiB) Viewed 9028 times
Re: Tachometer with hourmeter
Posted: Fri Jun 02, 2023 8:55 am
by Mr Zero
No, I've never come across an operating clock/tachometer combo guage in that diameter. I appreciate that you asked a different question, but if you'd like to keep the clock, have you considered a speedometer/tachometer combo guage instead? Many more options there and it would achieve the same functional end.
Posted: Fri Jun 02, 2023 5:40 pm
by ChickenPinz
Mr Zero wrote: Fri Jun 02, 2023 8:55 am
So are you proposing replacing the speedometer+trip_meter+odometer with a speedometer(GPS???)+tachometer?
And no, I'm pretty partial to the OEM speedo. It's just that I'd like a tach+hourmeter to go in that opening that is just hourmeter. Those are pretty standard on aircraft, FWIW.
Posted: Mon Jan 01, 2024 2:17 pm
by Stumbler
There's a small adapting ring. I remember buying one from SAV and I never got around to adding a tach. It was only $20.
Posted: Mon Jan 01, 2024 5:54 pm
by Mr Zero
ChickenPinz wrote: Fri Jun 02, 2023 5:40 pmSo are you proposing replacing the speedometer+trip_meter+odometer with a speedometer(GPS???)+tachometer?
Yes, a speedometer+trip_meter+odometer+tachometer in a single unit.
