Oil dripping from pan
ziegler
Post by ziegler »
The oil pan gasket is good but there's oil coming from above the oil pan on the drivers side. It's not from the oil cooler, does anyone has any ideas. I changed the O rings and the gasket of the oil cooler thinking that would solve the problem but it didn't. Can it be the exhaust manifold gasket? Thank you. Zig
Re: Oil dripping from pan
On the drivers side is the cylinder side so there are several possibilities.
But a pix of the area would help.
Andre
Post by Andre »
Pushrod tube seals drying up. Or the oil return tube. Both use rubber beveled washers to seal against oil leaks. Make sure the valve covers aren’t weeping either.
