Removing window on 710
Posted: Fri Mar 29, 2024 6:45 pm
by CaptainRon
Hello, help......I want to remove the driver's and passenger's side window for clean up/maintenance. Seems pretty easy to do looking at it. I see the 5 bolts below the window frame. After removal I can't seem to get anything to budge. Doesn't that frame piece just come out some how?....don't want to break anything lol....
Re: Removing window on 710
Posted: Sat Mar 30, 2024 12:34 am
by Hugues
I removed mines some months ago,
The bottom rail was glued, orange arrow,
Had to slide a knife, PITA, but did it.
Posted: Sat Mar 30, 2024 11:23 am
by CaptainRon
Thank you so much. I'll give it a try. Any resource for new gaskets for bottom rail of window?
Thanks again, Ron
Posted: Sat Mar 30, 2024 1:39 pm
by pcolette
Posted: Sun Mar 31, 2024 3:26 pm
by CaptainRon
Thank you Paul!.....
Posted: Wed Apr 03, 2024 10:38 pm
by ChickenPinz
Same as mentioned by others -- mine were tightly stuck and it took some quality time with a thin putty knife and patience so things don't get bent. Likely heating it would help as well.
Be careful when you put it back on that you don't plug up the drain hole.
Posted: Tue Apr 09, 2024 6:44 pm
by CaptainRon
I saw those drains, yes. I'll have to replace one side of tubing as it is absent. Does that just shimmy to the bottom of the door through that mid-hole in the door? It doesn't sit on any bottom fitting does it? I see the exit hole but haven't separated the two halves of the door.
Posted: Wed Apr 10, 2024 12:24 pm
by Hugues
Mines were also missing
i just bought a piece of tube and passed it through the door,
it exits a few mm at the bottom, we can see the tube in this picture
Posted: Thu Apr 11, 2024 3:16 pm
by CaptainRon
Thanks for showing me that. I just got some new weather stripping for the windows so that will finish this portion of my truck that is in 500 pieces :D
Posted: Sat Apr 13, 2024 9:50 pm
by CaptainRon
For anyone in the market for drain tubes for the windows this product fits perfectly.
https://www.amazon.com/dp/B085N2RV3W?ps ... ct_details
