Exhaust Pipe Flex
Posted: Mon Apr 01, 2024 8:20 pm
by CaptainRon
Got one of these stainless steel exhaust pipe flex kits from SAV. Just wondering if anyone else had this rig and if you painted it? It looks great now lol, just wondering how long it will look good in its original form or maybe I should put some high temp paint on there before I install it. FYI, getting some of those bolts off on the headers made me question my will to live..... Many thanks.....Ron
Re: Exhaust Pipe Flex
Posted: Tue Apr 02, 2024 9:04 pm
by rmel
Should be Stainless Steel -- no paint necessary.
At least mine are..
Posted: Tue Apr 02, 2024 10:39 pm
by CaptainRon
Thank you, I have my truck broke into a 100 pieces right now. It's in good shape with minimal rust, but I'm mitigating what I find. I just replaces the two side panels in the cargo area through SAV surplus. I noticed there is some really thin rubber lining between the panels. Any info on that or sources for replacement?........
Thanks again......
Posted: Tue Apr 02, 2024 10:50 pm
Posted: Wed Apr 03, 2024 9:13 am
by CaptainRon
Ok, thanks Paul. It seems thinner than 1/8 of an inch thick, but I guess it's just been compressed for so long.
Posted: Wed Apr 03, 2024 11:21 am
SAV used to sell the body sealant tape and I recall it was closer to 1/16" thick but was firmer and less compressible.
Posted: Wed Apr 03, 2024 10:35 pm
by ChickenPinz
Butyl rubber is the stuff I see used most in automotive when you need to seal two pieces of body panel together, but would like to be able to separate them. It's all over my Toyota trucks for access panels and for sealing the plastic under door upholstery.
3M Strip Calk, 08578, Black Color, Soft Butyl Rubber
https://a.co/d/aXo63f4
Posted: Tue Apr 09, 2024 6:41 pm
by CaptainRon
Thankyou Chicken Pinz......I did find some stuff. It's a tad thicker than the original but should work.
