Can someone tell me what the function of this is?
critter
Post by critter »
Small box with bayonet plug in front of the ignition coil. Upper right of the wind tunnel. Has a 4 wire plug going to it. What does it do?[img][attachment=0]IMG_3214.jpg[/attachment][/img]
Tyler
Germany
Re: Can someone tell me what the function of this is?
Post by Tyler »
critter wrote:Small box with bayonet plug in front of the ignition coil. Upper right of the wind tunnel. Has a 4 wire plug going to it. What does it do?Image
Your image didnt upload, if you had one. :(
1975 710M
2016 Ram 2500
2016 F-350 Superduty
32’ gooseneck flatbed
1981 M111 welder trailer
2011 M101A1 trailer (sold)
Voltage regulator, https://expedition-imports.com/voltage- ... n-eic2606/
If it's not connected you must be running with an alternaotr with a built in regulator.
critter
Post by critter »
Thanks for your reply. One of the wires, Dark Blue, broke off the connector. The regulator seems to be original. I also see the plug is no longer available at SAV.
Bob
Blue is the D+ output from the alternator to the regulator.
If it's not connected your regulator will overdrive the alternator.
You can just replace the connector with individual "FastOn" connectors.
For that wire gauge "Blue" 0.25"will do the trick https://www.amazon.com/Conext-Link-QDVF ... =1-19&th=1
Use a decent crimp tool. https://www.amazon.com/Haisstronica-Ele ... r=1-4&th=1
critter
Post by critter »
Electrical has never been my strong suit. I am not sure how old that voltage regulator is but it looks original. 50 years. I think it may be time to replace it also.
Thanks again. I appreciate the info.
Bob J
