Just last night, my throttle started sticking. When I take my foot of the gas, the pedal doesn’t come all the way back up. I tried blipping the had throttle to no avail.
I put a drop of oil on all of the rod ends and sprayed some oil on the pivot that the hand throttle pulls on( I removed the e-clip and pulled one of the bushings out first). It didn’t completely solve the problem.
Now when I take my foot off the gas, it comes up more such that the engine idles a 2,000 and the hand throttle blip brings the idle back down to 600ish.
I sprayed brake cleaner around the carbs in case there was a vacuum leak, but I’m convinced it’s the throttle linkage.
Any ideas?
Has anyone ever had to replace the springs?
Everything else functions as normal
Throttle sticking
rollingpinz
Throttle sticking
ChickenPinz
Re: Throttle sticking
I'd first pop off the ball-joints that go from the linkage to the carbs. See if the hang-up still occurs. That way you can isolate it to the carbs versus the horizontal linkage to the pedal.
710K
rollingpinz
So I learned something new about the hand throttle. I used to think the only way it worked was pull the handle to desired throttle position and tighten it in place.
But while I was disassembling and chasing sticking points, I noticed the handle was about a half inch higher than normal and there were threads sticking out.
With some experimentation, I learned that from the lowest setting, the handle can be threaded/backed out and it will hold that position.
This seams much easier than holding the handle where I want it and tighten it.
Oh joy. Problem (not a problem) solved.
