Exhaust pipe temperature
Posted: Fri Aug 15, 2025 12:07 pm
by jan.bauwmans
When I point at the exhaust pipes of each cylinder with a heat gun, the pipe of cylinder 2 is abt. 100 degrees Celsius colder than the others. Other 3 show more or less same temp.
Already checked :
- valve clearance
- spark plug fires, gap set
- idle mixture screws checked
- synchronized carbs and all nozzles in the top spray fuel
- ignition timed
- checked cylinder top and sides with mini camera and all looks ok
The pinz drives very good, just did a check of the temp during routine maintenance.
Anyone an idea what could be the cause ?
Tnx !
Verstuurd vanaf mijn SM-S928B met Tapatalk
Re: Exhaust pipe temperature
Posted: Fri Aug 15, 2025 12:51 pm
by Hugues
100 C difference?!?
How much do you measure on each?
Posted: Fri Aug 15, 2025 1:04 pm
by jan.bauwmans
Cylinder 1 3 4 abt. 310 degrees Celsius and nr. 2 abt. 200.
Posted: Fri Aug 15, 2025 6:41 pm
by ChickenPinz
Can you show us a pic of where you're doing the measurement? Presuming you're using a non-contact IR-type meter, it's important to make your measurements all at a similar distance so size of the sensed area will be similar.
I would swap spark plugs between two cylinders and see if the symptoms move.
Do you have good compression in all cylinders? Bad compression would result in poor power out of that cylinder.
Posted: Sat Aug 16, 2025 9:54 am
by jan.bauwmans
I measured at the same distance, cylinders 1 3 4 show abt. the same temperature. Switching the spark plugs doesn't solve it.
Posted: Sat Aug 16, 2025 4:37 pm
by ChickenPinz
I'd do a compression check now
Posted: Sat Aug 16, 2025 4:40 pm
by ChickenPinz
There's another old-school test sometimes called a power-balance test.
You one-at-a-time disconnect each plug wire and see if the RPM drop is the same. That'll give you an idea if all cylinders are contributing equally. If the RPM drop is the same, then I'd say the temperature difference is a red herring.
Posted: Mon Aug 18, 2025 8:59 am
by rmel
What your are describing is possibly a case of exhaust valve seat recession.
During the compression cycle the gases are escaping out the exhaust with no
igniting. Most prevalent at low RPM, at higher RPM and HOT some ignition
will occur.
The best test for this is a Leakdown test, with the cylinder under pressure
you can then literally hear the cause of the leak, either out the tail pipe if
Exhaust valve or into the sump if rings. A compression test will tell you just
that but won't tell you the cause.
If you have a seat recession issue, the root-cause is typically running too lean.
This could be for all cylinders, in which case #2 was the worst, but all will be
showing signs, or could be just one cylinder due to a Carb metering issue.
Posted: Sat Aug 30, 2025 12:58 pm
by Stumbler
I'm pretty sure Chickenpinz solution should work. If you pull one plug, the idle changes, then when you pull the hot pipe cylinder I'm betting the change will not be significant because it sounds like you have fuel mixture igniting inside the header. There's not a lot you can do that would be cheap and easy. Maybe try your preferred engine cleaning solution in the gas, but that will have fairly minimal effect. (I use Seafoam gas additive) Sound like most likely the exhaust valve is leaking during the compression cycle for some reason. Could be a spring, could be timing, could be crud inside on the seat. When was the last time you performed a valve adjustment? A valve adjustment is the only cheap and easy solution that I can think of.
Posted: Tue Oct 07, 2025 8:58 am
by JimmyC
Colder on a gasoline engine could be related to a richer mixture. I assume this is at idle? If so, try fiddling with idle mixture screw on that cylinder to see if it changes temperature.
