Power Steering
ziegler
Power Steering
Post by ziegler »
Does anyone out there in Pinz land have a wiring diagram of the power steering units for the pinz. I have the power steering on the 710 and it worked flawlessly until last year. I can only find one fuse but I believe there are several. I'm not an electrician but I have a good friend who is an electrical engineer but he needs to see a wiring schematic to help locate the problem. The unit was purchased from Expedition Imports and installed at Andres place in Texas. I've tried to retrieve the wiring diagram from EI but have not heard back from them. AS always, any input is appreciated. P.S. I just replaced the fuel pump and the input I received was spot on, thank you very much. Mark
Re: Power Steering
I believe the eSteering units come from Ezpowersteering out of the UK ?
https://www.ezpowersteering.co.uk/car-b ... pinzgauer/
Same ECU and motor at least. If you click on the manuals tab above link there's
installation instructions but they woefully lack detail. You could send them
a query on a schematic to help you debug this. I've not gone down that path
so have no first hand knowledge of the hook-up.
