Front Parking Lights
Posted: Wed Apr 19, 2006 5:00 pm
by IwanaPinz
Hey all,
It’s good to have the web site back.
My first problem has arisen.
The parking lights will not come on. I do have turn signals and emergency flashers. I did look for a lose connection but nothing seemed out of the ordinary.
Any suggestions? Please remember that I am a newbie at automotive repair and I have no experience with the electrical end. (Turn switch, see lights everything is good.)
Brian Hahl
1973 712 M
Posted: Wed Apr 19, 2006 6:18 pm
by M Wehrman
The ft lights do not have double filaments for park lights, Mark
Posted: Thu Apr 20, 2006 8:26 am
by Lightningpinz
Turn the light switch to the first click on. Check for "park" lights in the headlights. Next click full headlights. As Mark said the yellows won't come on as park lights.
Posted: Thu Apr 20, 2006 12:13 pm
by Twin Pinzies
The Pinz lighting system is awful!
There is no reverse light, yet there is a glove box light!
There are no marker lights on the sides of the vehicle at all.
The brake lights are orange-not red.
It cost a lot to bring the pinz's lights up to snuff, but it's worth it. I suggest orange/yellow marker lights for the front, red marker lights for the rear, and reverse lights. Then it would be DOT legal. And much safer to drive at night.
Posted: Thu Apr 20, 2006 9:32 pm
by M Wehrman
I did not mention that I "split" the circuit to the amber lights and now one is turn and the other is wired to my park lights.I used a smaller bulb for park,this helps with side visability a bit. TTFN,mark
Posted: Thu Apr 20, 2006 10:05 pm
by IwanaPinz
OK, I think I understand. The front amber lights should not come on at all unless they work as the turn signal or as the emergency flashers.
So I worried about nothing.
Splitting front signals
Posted: Fri Apr 21, 2006 10:21 am
by Pinz Enthusiast
M Wherman how is it that you "split" the front turn signals, I had this idea sometime back and after removing the light fixture could not figure out how to accomplish this possible simple task, andy detail or pics on how you did this would be appreciated.
Posted: Fri Apr 21, 2006 5:08 pm
by M Wehrman
I soldered a wire to the tip of one of the bulbs on each side I got the idea from those quickie trailer light kits that attach a pigtail to tailight bulbs,Then i used two layers of heat shrink over the existing center contact bar. I then ran the one wire from each light assy thru the existing grommet to a suitable instrument light terminal. This makes for a little more trouble to change a bulb,but leaving a little extra in the housing makes for easy desolder-resolder. Mark
