Need some restoration advice
Posted: Wed May 17, 2006 12:58 am
Well its finally time to start the full restoration to the body. I bought my 712M a year & 5 months ago, It looked really nice in white with the interior rhinolined black. Unfortunatly I have noticed some things that led me to belive that there was little prep work done before the purely cosmetic finishes were applied. So it is time to do the job I've been dreading, peeling all that rhinolining off. I plan to take it down to bare metal, fixing small dings and making mods as a go.
I have not decided on the bottom as the undercoating is in such great shape, I'm also a little concerned about how difficult it would be to remove. Anyone removed and replaced the undercoating yet?
So I would like to hear from anyone that has gone through this with tips and suggestions.
My idea for paint is: Self etching primer, Paint on sound barrier, and Epoxy top coat. I'll make a test piece and weather it while doing the rest of the prep work.
Any suggestions on removing the rhinoliner? Does heating it with a hot air gun make it easier to work? I may use a soldering iron with a knife blade to cut it if it doesn't create to much toxic fumes.
This is the part that will take the most time cause someone got a little carried away with the spray in the cab.
Note: rhinoline is used as a generic term, as I do not know what brand was used.
Miles
Miles
