radio colsole
Posted: Sun Jul 09, 2006 12:42 pm
by jgeesen
I need to get around to installing a radio in my Pinz. I'm just looking for an AM/FM/CD/MP3 head unit with a couple speakers.
Is it worth getting a marine radio? Is it just the face of these radios that are resistant to the weather, or the whole radio?
Right now I am leaning towards the consoles I've seen that mount between the head bumpers - radio facing forward and speakers at an angle to each front seat. I know these have been offered for sale, but I can't find any on the net.
Any help with links? Suggestions? Particular radio/speaker setups? Can 4 channel head units be bridged to only use one pair of speakers, or do I just lose the amp power to the front or rear pair? Mono would be fine in the(my) Pinz.
thanx
john
Posted: Sun Jul 09, 2006 2:30 pm
by PinzEOD
Whatever final choice you make on the radio setup, I recommend buying one that has a USB port on the front. Stick in your flash memory card with your favorite songs and go. I have yet to find a cd player that can hold up to the ride, the flash memory is pure digital and plays with nary a skip.
Posted: Sun Jul 09, 2006 4:00 pm
by milesdzyn
John check your PM
Miles
Posted: Sun Jul 09, 2006 4:09 pm
by mjnims
don't know if the bidding has ended yet but Brian M has one for sale on Ebay. That particular overhead console has been built in numbers here in AZ. As far as the marine radio goes, the only difference I found was the manufacturer provided some sticky tape to cover openings in the top of the radios housing and the front plate had a gasket to keep the weather out of the unit. I now just run an eclipse radio unit with much better results.
Posted: Sun Jul 09, 2006 4:56 pm
by PinzEOD
http://cgi.ebay.com/ebaymotors/Pinzgaue ... enameZWDVW
item 170005502672 if the link doesn't work.
3 days left as of this post
Posted: Tue Jul 11, 2006 11:46 am
by alanh
One thing the marine radios seem to offer that the standard auto stereos don't is a wired remote control. They differ in functionality, but some seem to repeat at least the important parts of the main unit display that the wireless remotes don't.
The wired remote opens up some mounting options for the main unit. If you're seldom using CDs or DVDs, I don't think the main unit will need to be within reach or even within sight.
Posted: Tue Jul 11, 2006 3:32 pm
by mjnims
the unit I had was the wired remote type. The ability to have the controls in your hand and not having to look at the radio was nice. It was just another wire in the truck though.
Posted: Thu Jul 13, 2006 6:32 pm
by jgeesen
I ran across the ebay unit before I posted this thread. That is what reminded me I need to get around to installing a radio setup. Was someone vac forming these out of ABS, also? I've seen some wired remote marine units on ebay. That would free up some mounting options.
Radio Box
Posted: Thu Jul 13, 2006 8:40 pm
by Pinz Enthusiast
Hey all, I was out bid on the radio bax and need one like the one listed on ebay pretty bad, does anybody know where I can get one, if they are still being made etc....also would that box work together with the tuffy center mount radio box?
Posted: Thu Jul 13, 2006 8:55 pm
by mjnims
Anything can be made to work together, it just takes a little thought. The radio units similar to the one on Ebay were made for a while but I have not seen any new ones in some time. I will ask around and see if the guy building them is still interested in making another one. The unit is not all that complicated. It is made from sheetmetal and then finished with the desired paint/spray on coating.
The Tuffy unit comes is one or two radio configuration. I am not sure what the single unit looks like. I have the double radio unit and use it to house my CB, AM/FM radio, controls for the intercom, interior dome lights and time-temp gauge. Oh yeah the Tuffy also holds the XM radio antenna and the GPS antenna. I mounted some marine grade speakers in the head guards and two more speakers on the rear roll bar.
Tuffy Radio Box
Posted: Sat Jul 22, 2006 11:09 pm
by Heed
Mike,
Could you post a photo showing your Tuffy set-up?
Also, what Tuffy model did you use?
