Weber carbs
Posted: Fri Oct 06, 2006 8:36 am
by pinzinator
This might be a complete waste of a post, but has the idea of Weber carbs ever been brought up? I had a set on a Datsun Z car once and it ran OK. Adapting the manifolds and linkage on the Pinz might be a problem. Just curious.
Posted: Fri Oct 06, 2006 9:15 am
by MASSIVE PINZ
I have thought of this.. BUT the older Webers that have a bolt pattern similar to a Pinz are progresives that flow WAY less than the Neniths. The Weber DCNF is similar but has all the quirks of the Zenith as well.
Neither of them have float bowls that are as superior as those of the Pinz Zeniths on serious inclines.
EFI is about the only way to beat the Zeniths- IMHO. Thats covered.
Posted: Fri Oct 06, 2006 2:11 pm
by Lightningpinz
Somebody did it. I got to drive it and at idle ok, take off from light ok. WFO forget it zenith better. Alotta work and a lot of negative improvement.
