Reverse Switch
Posted: Wed Oct 18, 2006 11:57 pm
by goudacheese
Has anyone installed the reverse backup switch? I have been looking all over the transmission trying to find where it installs and the only bolt that I can find that is big enough is where you fill the transmission! I was told it is above the shaft, but I still don't see it. :!:
Posted: Thu Oct 19, 2006 12:23 am
right above the trans output flange is a 17mm plug, pull that and you will see a plunger. (see picture)
You may have to cut the tail off the plunger to make it work, or if you have a new style one with a recess, just pull the old one out and replace with new one :wink:
Posted: Thu Oct 19, 2006 9:11 am
by Ugo
I confirm - I had to cut the "tail" with a dremel tool.
BTW, being afraid of risk of dropping the plunger into the gearbox, I put the reverse gear before undoing the screw plug.
Ugo
1977 710K
1990 716K
Torino, Italy
Posted: Wed Nov 15, 2006 3:33 am
by gunipinzmutt
Do I have to buy the switch from magna steyr or is it commonly available in the market? I have seen it in the spare parts catalogue with nr 7111850750, Kostal 8860; was it installed also in other cars?
Posted: Wed Nov 15, 2006 7:37 am
by Ugo
I am sure there are several alternatives.
I bought a Fiat Iveco spare part ... small Iveco vans and trucks have a ZF transmission, and presumably ZF use a standardized switch (and thread) on gearboxes they produce.
Ugo
Posted: Wed Nov 15, 2006 9:54 am
by gunipinzmutt
Thanks Ugo, your help is always useful!
gunipinzmutt
Posted: Wed Nov 15, 2006 6:13 pm
by ExpeditionImports
Readily available switch. Check with the Unimog dealers, same switch as used on the Clauss overdrives....whole lot better price.
Scott
Posted: Thu Nov 16, 2006 6:03 am
by EuroPinz
Hi there;
Here are the parts number:
7161225391 Kontaktbolzen ATS 24.2 (little connecting shaft)
7161850320 Rückfahrschalter ATS 666.4 (reverse switch)
7162850330 Anschlusssatz ATS 186.9 (Reverse switch cover with wires)
Best Regards
Jacques
Posted: Thu Nov 16, 2006 6:09 am
by EuroPinz
... here a few more pictures:
Good Luck
Jacques
