Pinz CTIS
Posted: Sat Dec 16, 2006 4:33 pm
by PinzEOD
OK Ok...It's not pretty, it's not fast, and you can't use it on the move. However, I can hook it up and sit in out off the rain and/or cold whilst airing up or airing down.
Actually, it's really not very practical. I was bored, I had the parts laying around. Tinkertoys for grown-ups you know?
I hook it up and preset the pressure regulator to the desired psi. Set it to 20 for off-road, or 60 for on, line pressure is limited to whatever I set it for. All six tires done at the same time.
Posted: Sat Dec 16, 2006 6:08 pm
by M Wehrman
I've been thinking of something along that line myself. I made my roll cage an air tank,I was thinking 6 short hoses ,one for each wheel. just hook up to cage and monitor gage until pressure is down,filling would be the reverse. It really takes some time to do the down and up with 6 tires!
Mark
Posted: Sat Dec 16, 2006 7:46 pm
by PinzEOD
That would be cool! There are swivel-type air fittings you could use. It could be a semi-permanent type of mounting with the individual hoses just swung up and tucked out of the way whilst driving. The 'hose' I used is big-rig brake line, very easy to work with and easily handles the tire pressure.
Airing down
Posted: Mon Dec 18, 2006 9:14 am
by krick3tt
Staun sells a six pack of deflators for trucks. Put them on and by the time you get to the last one the first one is aired down to the preset pressure. Then just take them off. Waaaaaay simpler.
Morris
Posted: Mon Dec 18, 2006 11:15 am
by MarkPinz
Yup ditto on the Staun deflators :wink:
Posted: Mon Dec 18, 2006 12:07 pm
by PinzEOD
Yeah, but where can I get a set of Staun INFLATORS? :lol: And besides, this was free. :wink:
airing down or up
Posted: Mon Dec 18, 2006 7:14 pm
by krick3tt
You got me there, Mike.
Can't beat free.
I had a OBA system in a bag left over from a previous mog, I consider that free for me. The pinz is 'start again' so all the other stuff that is left over from my mog days is frosting on the cake.
Morris
Posted: Sat Jan 27, 2007 4:44 pm
by PinzEOD
Version II
Image Image
Image Image
Air them all down at once, air them all up at once.
Posted: Sat Jan 27, 2007 11:28 pm
by milesdzyn
Mike....could you shot a more detailed picture of the clamp mount that holds the tubing to the top of the side bed panel in the picture. (top left) Is it available locally?
Miles
Posted: Sun Jan 28, 2007 8:52 am
by PinzEOD
Hi Miles,
They are Mcmaster Carr item number 3044T1, I-beam Clamp for Threaded Rod. $1.00 each plus shipping with next day delivery. I didn't check around town anywhere, Hughes Supply or Nedco would probably carry them or something similar. The clamping action is from below with a 1" long bolt, with a stubby bolt from above to hold the actual pipe retainer. I used a rubber coated metal wire routing clamp to actually hold the pipe against the clamp.
Posted: Sun Jan 28, 2007 7:25 pm
by milesdzyn
Mike....Great, I may have a use for them during the reconstruction phase of the Pinz. I have everything removed except for the Brake-Clutch assembly and the Dash, saving that for last.
Thanks, Miles
