Timing
Boelt63A
Timing
Post by Boelt63A »
I have a civilian distributor and pertronix set up. Question is Do I disconnect the vacuum advance on the distributor to adjust the timing or leave it alone?
Also the truck seems to run a bit better with almost 10 degrees of advance, is this too much?
Chuck
'74 710M
Ther eis no vacuum advance, that line removes moisture from the distributor.
A lot of guys run up to 10 deg btdc :wink:
Boelt63A
WOW
Post by Boelt63A »
Jim you have no idea how helpful that was!!
I have had terrible problems with condensation in the cap. I've had to all but rebuild the distributor due to rust in it. I bet that line is plugged somewhere. Just in time for a weekend project!! :lol:
Chuck
710M
ExpeditionImports
Post by ExpeditionImports »
In the rubber 90 degree elbow of that line there will be a brass jet...more than likely it is clogged. Do NOT completely remove it.
Scott
Vallejo, California
www.expedition-imports.com
Boelt63A
Post by Boelt63A »
It is, and I was wondering what it was. Luckily I haven't totally torn it apart trying to get it out.
Any advice on ho to clean it out?
Chuck
'74 710M
