Alternative Clutch/Flyweel alignment tool
Posted: Sun Feb 18, 2007 7:05 pm
by milesdzyn
Anyone know which GM Clutch/Flyweel alignment tool works on the pinz. I think it was a GM 10 spline?
Also any other tools that will replace the Pinz specific "gold plated" tools.
ex: VW flywheel holder works for the Pinz.
Miles
Posted: Sun Feb 18, 2007 7:18 pm
GM 10 spline , Toyota Landcruiser, Early 60's Mercedes , BMW 8)
Posted: Sun Feb 18, 2007 8:09 pm
by milesdzyn
Jim...Will BMW, 3-Series Models (not E36 M3), 1992 -1999 tool work?
Miles
Posted: Sun Feb 18, 2007 9:18 pm
All I Know is the splines on the 733i are the same. I use old input shafts for pilot tools, I use a cut off 64 Mercedes 4 sp input shaft 8)
Posted: Mon Feb 19, 2007 12:09 am
by M Wehrman
My last Pinz I used the alignment tool that came with the BMW clutch. I put a few wraps of aluminum tape to make up for the larger pilot bearing and woo,woo! All slid together nicely!
.02 for free!
Mark
Posted: Mon Feb 19, 2007 1:49 am
by milesdzyn
Mark....Do you remember the part no of the BMW clutch by chance. I was looking at a HD 4 spring for a BMW M3 but I'm not sure its a direct fit?
http://cgi.ebay.com/ebaymotors/SACHS-87 ... 1674QQrdZ1
Miles
Posted: Mon Feb 19, 2007 12:18 pm
by M Wehrman
I believe I got the info from the SDP site,If memory serves it was for the 7 series BMW. I bought the kit at Auto Zone,and it had a Sachs pressure plate,and came with a lifetime warrantee!! Of course the T-O bearing wouldn't fit ,but as easy as it was to pull trans ,I opted to reuse my old bearing. BTW,the replacement p-plate was substantially stiffer than my old one. Hope this helps.
Mark
Posted: Mon Feb 19, 2007 2:17 pm
by milesdzyn
Thanks Guys
Miles
