LED LIGHT BULBS
ms1223
LED LIGHT BULBS
Post by ms1223 »
Has anyone tried these LED light bulbs?
http://www.superbrightleds.com/other_bulbs.htm
I'm having a hard time finding 24v bulbs. I need some replacements and some spares. I had to "borrow" one today from my 416 trailer.
Swifty 72 710M
goudacheese
Post by goudacheese »
I am using the 1156 19 LED White for the front & Yellow for the rear. I am also using the 1156 White LED's for the inside spot lights in my 710K. The 12 LED bulbs are not that bright.
Your only limitation, is the creativity of your imagination!
ms1223
Post by ms1223 »
I think I'm going to try some in my M416 trailer. I hope this will keep the amperage down and the stress on the Pinz wiring Last year I burnt everything associated with the Green/Black tail light wire including the turn signal switch.
Swifty 72 710M
Mr Cheese- Did you use the wide angle bulbs (100 degree vs 12)? And as for the red LEDs, did you use the brighter '19' version? I am curious because I would like to order some for my Pinzgauer.
goudacheese
I don't know what degree the bulbs are but they look like the LED bulbs that ms1223 referenced. I am using the 19 LED Amber bulbs in the front parking lights and in the rear Hella turn signal lights that I added. Tail lights are already LED.
I found that if I use LED bulbs in both the front & rear turn signals they will not work, but if I use just 1 LED and a regular bulb the turn signal works.
