New Front Springs
Posted: Wed Mar 14, 2007 8:14 pm
I replaced my front springs finally. I've had them for six months! I have taken the coils off before in order to replace boots and wipe seals. That was no big deal because I didn't have to take the spring compressor off on put them on again-------It is very spooky knowing how much pressure is on them. My spring compressors are generic and don't fit as well as I would like!
Notes:
1---you must compress the spring to 10.5 inches
2---when you put the compressors on the new spring, make sure
they are as close to 180 degrees from each other as possible.
3---remove the shock and rebound strap for extra room.
4---I wrapped a small chain around the compressor for safety!!
5---be very, very, very careful
I'm sorry I didn't take pictures of the process for everyone.
I did take pictures of the result.
It sits at least 3 inches higher than before. The right front spring was extremely weak, due in part to the extra weight of the cattle feeder.
I now need to replace the back springs because it sits higher in front.
http://i101.photobucket.com/albums/m53/ ... 1072-1.jpg
http://i101.photobucket.com/albums/m53/ ... 2_1070.jpg
http://i101.photobucket.com/albums/m53/ ... 2_1071.jpg
Notes:
