Okay how do you get at the hand brake? and liner thikness?
Posted: Mon Mar 26, 2007 7:52 am
Getting ready to tear into the hand brake and need to know what the minimum thickness is for the hand brake liners. I assume that it is just before the rivets start digging into the friction plate. Also what is the thickness of the new liners?
Well I got all the bolts off, removed the E-brake hardware and still can't get the back cone off to get at the E-brake. Its binding up at the body mount and the E-brake pivot arm mounting point. It just gets wedged in no matter what angle I take.
It just is not possible that you have to remove the body to gain access, I have to be missing something.
I was able to peek in and see that the back lining was about 3/16" thick and very little wear on the rear friction plate.
Help!!
Miles
Help!!
Miles
