Lifeline: The Lifeline® enables users of a Master Disconnect Switch to retain a small amount of power for memory circuits common in fuel injection computers, radio presets and clocks. The Lifeline® is completely “resetting” eliminating the need to replace a fuse when the user tries to start the vehicle before first switching the Master Disconnect to on. The Lifeline® is a memory circuit retainer that will automatically reset after the electrical load is significantly reduced or if the Master Disconnect Switch has been switched to the on position.
Heres the link:
http://www.americanautowire.com/products/#Product6
I'm sure that it could be made by someone, and not sure if it will work with 24v systems.
Miles
