ProfPinz I Need your help on heat exchanger
Posted: Thu Apr 12, 2007 10:36 pm
Peter....Couldn't find your post relating to cutting open the outer shell of the heat exchanger. How did you cut it open, the weld seems to be along the top edge, but for rewelding it seems that cutting it along the flat just below the edge would be a better rewelding point. Just not sure of how deep off the top edge the weld has penetrated, thinking that 3mm should be right. How did you do yours?
Looking inside it looks like one of the heat fins has broken off and someone tried to reweld it in place through the outlet hole and really buggered it up. Are the fins made of weldable material?
For those of you not getting enough heat this may be some of the problem. The heat fins are critical for pulling heat away from the exhaust tubes, more surface area to pull heat off from.
Miles
Miles
