Getting ready to R&R my alternator
Posted: Mon Apr 23, 2007 2:02 am
by ABSOLUTSECURITY
Dennis mentioned that I need to change the wiring if I am installing a higher output than stock! I belive him!! :wink:
Dennis or anyone else with knowledge! Can you please help me along with this task?
I got my alternator rebuilt and rewound and it tested at 50 amps :D :D - I want to install it but I dont want to see smoke and fire when I do! Any help would be greatly appreciated!
Glynn
Posted: Mon Apr 23, 2007 7:47 am
by lindenengineering
Glynn
If you hold your hosses for a few days I will post some pictures of the conversion so that anyone can retro the install to their Pinz irrespective of whether its uprated or not.
That Molex connector is by the way the "achilles heal" of the system and accounts in our opinion to about 50% of all failures.
Dennis
Thanks Dennis!
Posted: Mon Apr 23, 2007 7:22 pm
by ABSOLUTSECURITY
Holding!
G
Posted: Thu Apr 26, 2007 8:33 am
Update.
We stalled on this for a few days, rain and snow stopped play in Denver.
That's the bad news now the good!
We have two alternators to install over the next two days, we will show how top modify the existing wiring to improve the standard alternator harness; then install an uprated alternator c/w 100A breaker and/or fuse protection. By the way I actually saw a 100A fuse the other day with a built in led that illuminates as a warning when the fuse blows. Innovative!
I am anxious to see how these two protection systems might perform on the Pinzgauer, a feature that is now standard on most of the modern vehicles you find these days.
Dennis
High Voltage Alternator wiring upgrade
Posted: Mon Apr 30, 2007 7:15 pm
Gents
Here is a shopping list for parts if you intend to do a DIY upgrade install using a 55 or 75 amp alternator.
There is some soldering and drilling activities to accomplish the job right first time. If you are not a competent solderer then try to find someone who can do it for you or buy a kit from us.
All the following is available from those folks at Napa.
6 off feet of 8 gauge multi strand wire, pt # 738802
1 0ff 100 amp circuit breaker pt # 782-3114
1 off ring terminal part number pt # 721128 (size 5/16)
3 off ring terminal part number pt # 721127 (size 1/4)
1 off grommet to accept the #8 wire
A selection of wire ties.
Some shrink wrap
2 off machine screw #10 for circuit breaker
2 off machine nuts
2 off flat washer
2 off lock washer, and/or loctite
Modus Operandi
Remove the alternator cover, disconnect the batteries (very important).
Expose the terminal at B+ve on the starter and loosen the nut with 13mm wrench.
Loosen the nut on B+ve at the alternator with 10mm wrench.
Disconnect field circuit, ground and plug connector. Install upgraded alternator. Reinstall field, plug and most importantly hook up ground wire to mounting bolt.
Remove the molex connector and take a look at the connectors.
Take an opportunity to clean the connectors at this time, repair any that look in poor shape but ignore the left connector (original B+ve if it looks burnt. The ones that need to be kept in good contact/condition are the field wires.
Mount the 100 amp breaker as shown. Use loctite to secure the breaker to the tin cover. (you don't want that flopping about if it comes loose!)
Cut a suitable length of 8 gauge wire to run between the starter post and the breaker. Bare the insulation and solder 5/16" ring terminal to the starter end doing the same at the other end but using a 1/4" terminal.
Don't forget to use some shrink wrap on the soldered ends.
Connect the wire as shown secure both ends and tie up against the existing harness as shown.
Drill a suitable hole in the cooling "tin" as shown and insert the grommet to test. Now make up the link to the alternator using the remaining 1/4" ring terminals soldering them together. Slip this through the grommet and connect as shown. Now use some dielectric grease on the old molex connector and insert it as original.
Take some time to check the field terminals for condition and fraying. If all looks good re-connect the batteries. Check continuity with an volt meter and run up the truck
Test the system with a volt meter stretched across the battery terminals. At idle (900/950r/m) a voltage of about 25.3/26.8 should be seen. raise the revs to about 1000r/m and it should be around 28.2/28.4. Remember there is always a trade off on amp output and threshold performance, so an increase in idle revs may be necessary to get the unit to put the light out.
Once running satisfactorily you can remove/cut out the original B+ve at the alternator and tuck it back with insulation should you wish to downgrade the system at a later date. This is desirable if you intend to use the breaker since should it trip the power will go to the batteries via the original harness that might let the smoke out!
Note you do not need to use the breaker you can put a "jointer" in it s place or even wire directly. You will have to make provision to remove the cover in the future to service the alternator. In the end it's your choice.
Best of luck and credits to Eric Maybee who had his Pinz done first at our shop and then set of to Wichita through the night with his dog to keep him company. Apparently he arrived safe, but tired. Thanks Eric for your business! Very nice truck
Dennis & John
http://i2.photobucket.com/albums/y14/li ... 010009.jpg
http://i2.photobucket.com/albums/y14/li ... 010010.jpg
http://i2.photobucket.com/albums/y14/li ... 010011.jpg
http://i2.photobucket.com/albums/y14/li ... 010012.jpg
http://i2.photobucket.com/albums/y14/li ... 010013.jpg
http://i2.photobucket.com/albums/y14/li ... 010014.jpg
Posted: Mon Apr 30, 2007 7:50 pm
by Erik712m
Hi Dennis, The alternater worked great to day seems to be keeping up great with the 1200 watt A/C inverter. drive line work seems to be a big upgrade at take off. can't wait for the next set of upgrades. I'll see you next month
Posted: Mon Apr 30, 2007 8:08 pm
by milesdzyn
Dennis...Nice write-up, I've copied it to a MS Word doc. for later use. I want to upgrade, but since both of my alternetors are still working just fine, I cant see scraping one for the upgrade at this time. Eventually I will upgrade them both.
Again thanks for sharing your experience with us.
Miles
Posted: Mon Apr 30, 2007 11:32 pm
by M Wehrman
Dennis,those wheels are way too "pretty" for a Pinz! What next,neon tubes for the underside? :lol:
Posted: Mon Apr 30, 2007 11:44 pm
Oh those wheels, made in China no less!
Yes they are attractive and I suppose at the stretch of the imagination some coloured neon might look quite nice at night from the underside. At least one thing; With the size of the Pinz you could put some big boom boxes in the back and wid de hi amp alternator broadcast dah Reggie Beat man!
Yeh mon reaal cool, pass me some of dat Appleton's wid de Coke.
Dennis
Posted: Tue May 01, 2007 6:31 am
by mjnims
Mark, Are you picking on my tubes again?
Posted: Tue May 01, 2007 12:41 pm
by M Wehrman
I knew I would get your attention! :lol:
Mark
Posted: Tue May 01, 2007 3:10 pm
by Erik712m
http://i177.photobucket.com/albums/w205 ... 000082.jpg http://i177.photobucket.com/albums/w205 ... 000071.jpg Rims seem to handle well here in Kansas wider tires sure seem to help in the mud and sand.[/img][/url]
