New Shocks from Doetsch
Posted: Mon Apr 23, 2007 7:03 pm
First off, I apologize for the long post but hope it is worth it to some of you.
Having recently finished an upgrade/replacement of shocks on my 710, I thought the project might be of interest to others considering new shocks.
The existing ride was rougher and more jarring than I expected and after having that seconded by a fellow Pinz owner I removed one of the rear shocks and found that it compressed and extended much too easily. Some research around the forums, etc. suggested that a NAPA shock might do the job but at $93.00 each were not cheap for a stock shock. Ranchos were often mentioned but some members had strong reservations about using them. I felt that at $76.00 each (5000 series) from SAV they were worth a try so I ordered a pair and put them on the rear. Definitely a STRONG improvement in the ride. Smoother, less jarring and traction was improved as well. Was about to order Ranchos for the front also and then I heard about Doetsch shocks for the Pinz. From what I understand, a few years back one of the Pinz dealers or groups arranged to have the shocks designed by Doetsch specifically for the Pinz.
Patrick at Expedition Imports had customers who had bought them and thought they were great. Thilo at T-LO's Ultimate reviewed the specs and thought they would work out well also. Doetsch apparently only sells directly to the end user, so I ordered a set of 4 from Bobbi at Doetsch and was told they would be $99.00 each and would take about 4 weeks to build and ship. The model I ordered is HV1-3166A which is an anodized aluminum shock with valving designed to allow it to mount with either end up. They can also have a remote resevoir added if you want.
The shocks arrived in about 4 weeks and looked great!
I had ordered all new bolts and nuts from SAV since I noticed one of the rear bolts I removed was bent and also I figured if I'm installing new shocks I might as well go all the way. Installation of the rear shocks was very easy and took about 30 minutes.
The front shocks take a while longer as the doghouse has to be removed and also the coil, suppressor and lower tin infront of the fan. I ran into my only problem trying to install the upper (red anodized) end through the chassis hole. It wouldn't fit due to its larger size.
This is where it is fortunate the shocks can be mounted either end up because the other end fit perfectly.
The overall install was not bad at all though having the correct wrenches for the left front is a must as access is tight. The ride is VERY nice and so improved even my wife mentioned it!
I don't do any severe offroad so I can't say how they will do for that, but they are definitely nice on the road and rough trails.
You can reach Bobbi at Doetsch at 1-800-874-6257. There website is at www.doetsch-shocks.com.
