Carb adjustment help
Posted: Wed May 02, 2007 9:43 pm
Arrgh. Removed the fuel pump, oil cooler assy, oil filler tube, and dip stick. I cleaned up the block and all associated parts. I replaced every single gaskets and o-ring in all the above assemblies.
I put everything back together and then the truck ran like crap. I checked all the electrical connections, etc. Would not idle at all. Ran fine giving it some gas, but would not idle. Then I fiddled with the adjustments screws on the carbs. Still not idling right.
How do I adjust the carbs? It didn't seem to make any difference where the adjustment screws were. I saw in the manual to adjust them all the way in, the turn them out 2.5 turns. Still didn't mke much difference.
I did turn the idle speed adjustment up till it idled, but still very rough.
When you sync them up do you use the four adjustment screws on the base, or use the idle speed adjustment screws?
Still not sure why doing the work I did (before fiddling with the carbs)would have changed anything?
