Unexpected Pinz Picture
Posted: Fri May 04, 2007 12:45 am
by todds112
I was looking into one of those little goose-neck map lights (like we coppers have in our work cars) to see if any were made for 24 volt systems. Anyway, I found a product called Littlite and was looking at the web-site. Found my way to their photos page and this was the first pic to pop up:
Kind of ironic. Also something else weird. Ours are made by Federal Signal, and the model is called a Littlite. Littlite also appears to be a seperate company making the same thing. Wonder if the Littlite company makes the ones that Fed Sig sells. I can't see competing interests allowing the same name for similar products without law-suits flying.
Posted: Fri May 04, 2007 5:26 am
by EuroPinz
Posted: Fri May 04, 2007 6:11 am
Todd,
Did you find a 24 volt gooseneck? Would like to get one also.
Posted: Fri May 04, 2007 7:38 am
by lindenengineering
Hey Jaques
Thanks for the pictures.
That looked like lot of fun.
Regards
Dennis
Posted: Fri May 04, 2007 2:24 pm
by todds112
pcolette wrote:Todd,
Heard back for Fed Sig and Littlite. They do not make an application for 24 volt.
Posted: Fri May 04, 2007 2:50 pm
Find out what bulb it uses and swap it for a 24v bulb, it really is that simple
Posted: Fri May 04, 2007 6:42 pm
by todds112
Jim LaGuardia wrote:Find out what bulb it uses and swap it for a 24v bulb, it really is that simple
Is that OK for the models that use a dimmer switch?
Posted: Fri May 04, 2007 9:54 pm
24v uses less amperage to operate in most cases ,and a dimmer switch is just a reostat . Go to Pep boys (or your local parts house) and get a cheepie to try out if you want.
I have converted a few 12v items to 24v, just use your noodle and common sense.
Posted: Fri May 04, 2007 10:57 pm
by todds112
Kind of ironic they sponser vehicles in a rally and have their name all over them and don't make a product to go in them.
Posted: Sat May 05, 2007 1:54 pm
by alanh
I have a 12v LED Littlite in a Toyota and really like it. The LEDs are nice because they run a lot cooler than an incandescent bulb. Its also got that red/white light feature although I can't say I've used it that much. I'm pretty sure I've seen the LED versions available in 24V, but they aren't cheap.
In my C303 I have a DC/DC converter to provide 12V for radios and such which would easily power an additional lamp. If you only wanted to run that one lamp, there are some small converters (powerstream makes one) that should do the job.
Posted: Mon May 07, 2007 5:01 am
by EuroPinz
@ Dennis,
You bet they had a lot of fun - and quite honestly being 4th overall is really not bad when one think that they were competing with 30 years old offroad vehicles against brand new Nissan, Toyota's, .... and other offroad vehicles that were all prepared by the manufacturing company for that specific race.
Often they would see these vehicles pass them at high speed (since they were faster then a Pinzgauer) to finally find them again behind them in the difficult section of the daily trip. On the asphalt, the Pinzgauer were always last, but when it came to showing it's possibilities in an offroad terrain, they would leave the crowd of new offroad vehicles far behind them. But the team only took 4th due to lack of highspeed on average and normal roads.
But in order to reach that score, the evenings looked a lot like this:
Best Regards,
Jacques
Posted: Mon May 07, 2007 8:58 pm
Jacques
This is what I like most about a Pinz, the ability to tear it open in the field and fix it.
I liked the pictures, it brings back memories of Raid Afrique and 2CV Citroens in the Hogar. I competed in 1971/72 with Dalle Freres of Roncq Nord when I was an exchange student in Lille. Again nice pictures.
Best regards/Amities
Dennis
Posted: Fri May 11, 2007 2:08 am
by EuroPinz
Dennis,
I have send you an email - for info
Best regards,
Jacques
