Compression psi
Posted: Fri Jul 20, 2007 6:59 am
Gents,
This may have been covered, but I can't find it in here using the "search" feature...
What should my Pinzi's cylinder psi read when doing a compression test? I can't even find a value in the repair manual (psi, atm or kPa).
Cylinders 1, 3 and 4 gave a reading of 120 psi, while number 2 gave an initial reading of 120, then topped out at 140 after cranking a few times without releasing pressure on the gauge. I did this with the other three cylinders, but they never climbed above 120.
Thanks!
Steve
1973 712M
Thanks!
Steve
1973 712M
