Turn signals
Posted: Mon Sep 17, 2007 5:49 pm
by critter
Turn signals seem to be slow then fast. No consistancy in they frequency. Is this an electrical gremlin Any suggestions?
Bob
Posted: Mon Sep 17, 2007 10:40 pm
by lindenengineering
If you have the original bimetalic flasher can it's indicative of the unit slowly going south.
Dennis
Turn Signals - Electronic Flasher?
Posted: Tue Sep 18, 2007 8:16 am
by Heed
Dennis,
I take it that it would just be a straight "swap out" for the old mechanical flasher to an electronic one? I'm a little auto-electric challenged...
Bob
Posted: Tue Sep 18, 2007 4:01 pm
by McCall Pinz
My flasher is doing the same thing and just this morning I ordered the Buss 24v 3 prong electronic flasher replacement unit. It took the Napa store a while to look up the part number, so in case someone needs it- Buss BE234 = Napa EG23.
I haven't received it yet, so I hope its correct.
Oh $17.99 and I should have it tomorrow afternoon!
NAPA flasher
Posted: Tue Sep 18, 2007 5:25 pm
by cwblevins
I was having the same problem and replaced the flasher with the NAPA EG23 and it works great. You might want to seal the seam with a bead of hot glue to make it water resistant. I mounted the flasher using the stock bracket by grinding off the dimple that holds the stock flasher onto the bracket and hot glued the napa flasher on then put a cable tie around it for good measure.
Curtis
Flasher replacement
Posted: Thu Sep 20, 2007 12:04 pm
by critter
Alright guys. The unit you recommend fromn Napa (EG-23)only has 3 posts. How did you hook it up???? The unit I presently have has 5 posts, only 4 are used.
Bob
Posted: Thu Sep 20, 2007 1:44 pm
by Wayne Roberts
Posted: Thu Sep 20, 2007 2:46 pm
by McCall Pinz
I haven't done mine yet, but am pretty sure my original unit has 3 prongs. Here are the sdp-pinzgauer.org directions with some codes that might help with your 5 prong unit.-
http://www.sdp-pinzgauer.org/html/elect ... asher.html
Posted: Thu Sep 20, 2007 2:56 pm
by critter
Gotter done. Works great thanks.
Posted: Thu Sep 20, 2007 10:51 pm
by McCall Pinz
Hey, got mine hooked up too- you were right, there were more connectors, but using the codes from SDP worked perfectly
