Pertronix ignition
Posted: Tue Sep 18, 2007 11:11 am
by EuroPinz
Is there a Pertronix ignition to be found/purchased that will work on a swiss Haflinger? What else needs to be done for it to be converted into a civilian ignition, spark plugs, wire, rotor cap, ...etc
Regards,
Jacques
Posted: Tue Sep 18, 2007 11:32 am
by Jim LaGuardia
Don't know about a Pertonix that fits , but a Pinz cap adaptor and a stock civilian Hafie cap should work.
Posted: Wed Sep 19, 2007 12:51 am
by EuroPinz
Thanks Jim,
As usual you're there to help out. I'll check down here and see if maybe one from a Fiat will work. I'll keep you updated.
Regards,
Jacques
Posted: Tue Oct 02, 2007 1:57 pm
by SDPintheLBC
Jacques -
Did you have any luck with the Pertronix?
Posted: Wed Oct 03, 2007 12:52 am
by EuroPinz
Well, I haven't been able to find a Pertronix yet - but I found out that here in Europe there is an electronic ignition conversion kit that works with the Haflinger and is made by the company LAUBERSHEIMER. Costs here in Europe 80 Euros and has even a build in LED to help you with setting the timing.
Regards,
Jacques
Posted: Wed Oct 03, 2007 12:56 am
by SDPintheLBC
Sounds promising. Keep us informed!
Posted: Wed Oct 03, 2007 1:17 am
by EuroPinz
The Laubersheimer Ignition seem to work just perfectly. A haflinger owner told me he has been using one for a while and loves the fact that the LED allows setting it perfectly - even while offroading.
He has a complete civilian kit on his Haflinger and had recently mudd in the ignition while offroading. He simply disassembled everything, cleaned everything and put it back together using the build in LED to set the timing again.
Here is the webpage of the company: http://www.laubtec.de/index.html
However, the webpage is only being build hence it is far from being complete.
Since it is in german I'll give you a quick summary. The company specialises in building electronic ignition kits for oldtimers - cars and motorbikes.
Regards,
Jacques
Posted: Wed Oct 03, 2007 11:19 am
by SDPintheLBC
Jacques -
Thank you. I just sent them an email.
