UPDATED: Easy/Cheap Dual Note Horn
Posted: Thu Oct 04, 2007 8:39 pm
by todds112
I found a Hella 24v horn on Ebay and bought it. After trying it, it's a really high tone. Not really any louder than original one. I thought about using both for a "dual tone" effect, but don't want to fry a relay or something.
UPDATED BELOW
Posted: Thu Oct 04, 2007 11:15 pm
by Jim LaGuardia
There is no relay, just a simple circuit completed at the button contact.
If both horns together don"t trip the breaker, it should be fine.
by todds112
Have to try it. Thanks Jim.
Posted: Wed Oct 10, 2007 5:04 pm
by todds112
Works great, sounds great!
http://cgi.ebay.com/ebaymotors/HELLA-SU ... dZViewItem
I bought this a while ago, never have liked the Pinz horn, thought it was just too weak, and kind of low toned. Sounded like a sick nanny-goat to me. So I got one of these. It sounded just as bad, as it was a very high tone, not fitting a beast like a Pinzgauer.
I decided to try them together. Sounds really good and no breakers are tripping. Has that dual note effect now. Not an air horn but not bad for 20 bucks. Best thing was there is already a threaded bracket just to the right and above the stock horn location, and the bracket that comes on the horn makes it ift perfect in that spot. Some OD green paint and it's good to go!
Posted: Wed Oct 10, 2007 5:13 pm
by mjnims
That would be the location for the horn when you have the blackout light.
I think it is funny that the pinz horn is so weak but it sounds like a train horn compared to the one in my Isuzu NPR. Must be a cab forward thing.
Posted: Thu Oct 11, 2007 7:02 am
by Foz
http://www.rallylights.com/hella/horns.asp
I used the low tone Hella Superhorn... worked great.
Horn wiring
Posted: Thu Dec 20, 2007 11:37 am
by grayroad
Did you wire in series or parallel?
Posted: Thu Dec 20, 2007 8:57 pm
by MarkPinz
Well....I kinda like my stock 710K horn it sounds like the road runner "Beep Beep" from the old Warner Brothers cartoon days :wink: Didn't see Michael's comment on the other thread till now :oops:
Re: Horn wiring
Posted: Mon Dec 24, 2007 11:39 am
by todds112
grayroad wrote:Did you wire in series or parallel?
Series. Just added one more slide on connector to the existing one.
add on horn wiring
Posted: Wed Jan 09, 2008 7:26 am
by grayroad
I got the same $20 horn. I piggy- backed the existing wires...I guess that's wired in parallel. It's very loud now! Not anemic anymore! Still kinda high pitched but nice for $20.
