How mush exaust smoke is too much exhaust smoke?
Posted: Fri Feb 01, 2008 10:22 am
by LibTimothy
How much is too much? Having no reference I appeal to you experts out there.
Here is a normal cold start up.
There is no smoke on warm start.
So, OK. On the scale of 1 to 10 with 1 being "Not too bad, just watch the oil" and 10 being "Stop driving now and find a repair shop", where am I?
Timothy
Posted: Fri Feb 01, 2008 10:46 am
by bernhard
Both of my pinz do about the same amount of smoke on a cold California morning (45-50) degrees). It goes away rather quickly in about 1-2 minutes.
Posted: Fri Feb 01, 2008 12:21 pm
Mine was about half that bad, but burned half a quart of oil every tankful. Thought it was bad intake valve seals, turns out there weren't any! Replacing them made absolutely no difference. Ultimately turns out it was worn rings/poor cylinder finish.
But I drove it for over 20,000 miles (32k km) before even attempting to fix it and it never changed, never got worse, better, or was a problem. I just had to keep an eye on the oil level. Just drive it and enjoy it!
Posted: Fri Feb 01, 2008 12:37 pm
by ScottishPinz
Mine 'smokes' at least as much as that. I was very worried as it idled away before its emissions test filling the garage with smoke... turns out its mostly steam on a cold day and passed its emissions with flying colours!
Posted: Fri Feb 01, 2008 6:31 pm
by Kiwibru
Same here. I have noticed more smoke on start if the truck has been sitting a long time and I have to re-fill the carb bowls. This of course requires a bit of cranking. That seems to allow a bit of extra oil to slip into the cylinders and that has to get burned off when it does start. As the weather warms up the problem is less. I don't worry about it.
Thanks.
Posted: Sat Feb 02, 2008 7:52 am
by LibTimothy
OK. Sounds like this is fairly normal exhaust smoke.
My oil usage isn't bad... especially when compared to my old Toyota and old Ford Ranger. They were both way worse. I expect the Pinz to use/leak a little oil. I'm just not sure how much is too much.
Thanks again for sharing your knowledge!
Timothy
Posted: Sat Feb 02, 2008 5:28 pm
by todds112
Yup looks like mine too. Goes away when she gets warmed up a little.
