Heat duct
Posted: Fri Feb 15, 2008 1:57 pm
by Brickren
Hello. Has anyone used exhaust flex pipe for heater ducting? Both the small diameter and large diameter tubing? I think that it would be insulated more than the cloth flex tubing. Thank you. Brian
Posted: Sat Feb 16, 2008 5:47 pm
by Lightningpinz
Haven't tried it because it in my humble opinion that would be much worse than cloth wrapped ducting. The steel would be an excellent conductor of heat. This would cool the heated air in it's travel to the front. If you were to insulate the flex exhaust pipe before you install it. That should make up for the conductivity of the steel pipe. I am running some flexible "plastic" pipe that Dennis got. It is about 1/8" thick stuff with a wire like a dryer duct. I'm running it from the heater box to the valve. It cost if memory serves about $2.00 per foot. I'll get more later and wrap it with duct tape or aluminized insulating wrap or something and run to the front. Check around, call around and see what you can get. Don't limit your search by what has been done.
Posted: Sat Feb 16, 2008 7:35 pm
by Ken A
Five years a go I needed to insulate the heater hose better like most of us in the colder states.
I decided to replace the old hose and insert the new hose in a slightly larger aluminum flex hose as a protective shield and insulator. (An air space is created between the smaller inner hose and the larger outer aluminum flex hose) I did not clamp the aluminum flex hose end because I wanted any water that got into the hose system to be able to drain/dry out.
It has worked very well as an insulator and the difference very noticeable.
Ken A.
Posted: Sat Feb 16, 2008 11:39 pm
Ken,
Sounds like a great idea! Do you recall where you found the aluminum flex hose?
Posted: Sun Feb 17, 2008 5:09 am
by Anthony
What is exhaust flex pipe for heater ducting made up from ? does it have any asbestos in it. The problem cold be that it is not intended for the human environment.
Posted: Sun Feb 17, 2008 7:05 pm
by Ken A
pcolette wrote:Ken,
Sorry Paul, it was too many projects ago.
If I didn’t get it from Home Depot then it came from McMaster Carr.
Sorry not a lot of help.
Ken
Posted: Sun Feb 17, 2008 8:08 pm
by Erik712m
Brian Double wall pipe would cut down a little bit on heat transfor. I like the idea of plastic pipe but would be worried about the melting point of it. John do you now what the melting point is? do you have a data sheet? Lowes carries a flex double wall pipe close to the same size
http://www.lowes.com/lowes/lkn?action=p ... lpage=none when i finally get around to installing my gas heater I plan on having stainless steel bent and insulated.
Posted: Mon Feb 18, 2008 9:52 am
by Kiwibru
The product from McMaster Carr is:
53335 K13, 80mm Poly re-enforced rubber hose, metric, temp. -25 to 275 F.
The insulation jacket is 4463 K145, Un-slit foam rubber insulation, 3 1/8" ID.
I wrapped the ends close to heat source with aluminum tape and it works fine.
HTH
Posted: Mon Feb 18, 2008 12:58 pm
by McCall Pinz
The Lowe's vent you linked to is Class B vent for gas water heaters and furnaces and should handle the heat. I think its rated to about 350 degrees
Posted: Mon Feb 18, 2008 8:23 pm
Any hardware store (worth a sh*t) should carry aluminum flexible dryer vent, probably available in both 3" and 4" sizes. At least around these parts.
Posted: Mon Feb 18, 2008 10:21 pm
by Lightningpinz
Have no data sheet for the plastic pipe. Has been on summer and winter now. I tend to push shifts in the mountains at max posted speeds on the console. Up and Down shifts at max speed for power in the mountains. I also run 104 kilos per hour for 5 or six hours from Denver to Grand Junction. So assume the heat rating is adequate for a Pinz. I have tried the aluminized duct/emission system ducting for the heat riser tube. It lasted about 3/4 of a year. The flexing of the engine killed it in one spot and rubbing around a radius wore thru in another.
Posted: Tue Feb 19, 2008 6:04 am
by Willard Foley
Bricken, I noticed your location is NW PA, where are you located ? I just purchased a Pinz last week and I am located in NW PA as well.
Posted: Tue Feb 19, 2008 7:48 am
by Erik712m
Hi John, I think Kiwibrew post the data.
Posted: Sun Mar 02, 2008 10:53 am
by Erik712m
http://www.selbyboatcentre.co.uk/chandl ... cts_id=143 I thought i might post this I have placed an order and will to see how it works.
Heat duct.
Posted: Sun Mar 02, 2008 12:45 pm
by Brickren
That looks like the ticket. Wish I would have seen that a week ago. Let me know. I wont install my new tubing till I hear from ya. Brian
