lifting points
Posted: Fri Mar 07, 2008 2:13 pm
by TurboJim
I want to lift my pinz 712 on a lift is there any lift points recomended for a regular shop lift
Posted: Sat Mar 08, 2008 11:58 am
by MarkPinz
In an earlier post before the site crash, believe it was recommended to lift a 710 under the body mounts? Can't remember about the 712 thou?
Posted: Sun Mar 09, 2008 8:28 am
by TurboJim
MarkPinz wrote:In an earlier post before the site crash, believe it was recommended to lift a 710 under the body mounts? Can't remember about the 712 thou?
i do remember that but i could not find it Thanks
Posted: Mon Mar 10, 2008 10:35 am
by M Wehrman
I have lifted several Pinzes using the lip under the rub rail. Obviously one needs to have an above ground lift....
Posted: Wed Apr 23, 2008 10:24 pm
by Scooter
I want to put my 710m on jack stands so I can rotate the tires. Are the lifting points under the body mounts the best place to do this? I looked at supporting it under the axle, but there is not enough room for the bottle jack and a jack stand. Here are the body mounts below.
I plan on doing one side at a time.
Front
rear
Any others ?
Scooter
Posted: Thu Apr 24, 2008 10:02 pm
by MarkPinz
That's the spot
Your undercarriage looks allot newer/cleaner than mine
Posted: Thu Apr 24, 2008 10:16 pm
by Scooter
Thanks, I had in under coated not long ago. Since we have not been able to drive our trucks here in Wis, it has stayed clean.
Well at least I can rotate the tires, even if I can not drive it yet.
Scooter
Posted: Thu Apr 24, 2008 10:22 pm
by Erik712m
very nice scooter
