Jer Bear
Charging light comes on and shows?????
Jerbearyukon
only 23.4 volt charging at batteries. Stays on for about 3/4 of and hour on three seperate trips . Then I start her and no light. Check charge at batteries and it's 28.3 volts
. Anyone know what's going on here. I keep waiting to have dead batteries but so far she has been starting ok.
Jer Bear
Jer Bear
Jerbearyukon
Ok so I have pulled the molex - it was a bit dirty - cleaned it up and put the anti oxidant grease in it. Checked behind the cowling and everything is tight there. Checked the relay under the heat ducting (no this could have a better spot to be I would think and I may move it later. It was iffy so I pulled it and cleaned it all up. Then Dennis suggested to pull the regulator and clean the back of it and make sure it is making good contact to ground with it's frame (have to do this now).
I will let you know what the results are
My Pinz had charging probs from day one
Taking Jim's advice the Molex visually looked OK. Upon closer inspection the female connector for the red wire had been hack / re-cramped back together. It was holding on by a single strand of wire & arching. Re- stripped the wire with new female & finally obtained the correct charging rate
Just get in and go....
Jerbearyukon
So what do you get at the battery terminals and how do you check the current out of the alternator
. You see I am an electrician but I HATE DC. there are so many things that go wrong with DC. bad grounds moving parts etc. Then try to trouble shoot.
Anyway we are all about CURRENT. I want to see what CURRENT is coming out and everyone tells me "oh just check to see that you have around 27.5 - 28 volts at the battery terminals and your good. BUT it's the current that charges the batteries and you just need enough voltage to overcome the voltage of the batteries.
Sorry to rant. I just can't seemed to find a clip on DC ammeter than doesn't cost you your left arm and right nut
Jer Bear
Jer Bear
If you are worried about the current, go to any automotive store and buy a cheap dashmounted ammeter. Disconnect one lead to one battery (doesn't matter which of the four leads) and temporarily hold the ammeter to complete the connection (you can use spring clips to hold it together for a test).I just can't seemed to find a clip on DC ammeter than doesn't cost you your left arm and right nut
But the voltmeter is the proper way to go. If the batteries are getting 27-28V (13-14V per battery) they are getting all the current they need. If this happens while the lights are on, the fan, and the wipers, you have all the current a stock truck needs. Pull too much current (lots of lights, etc.) and the alternator can't supply enough current and the voltage to the batteries starts to fall.
I've seen at least one truck where the voltage regulator failed and the batteries were ruined by overcharging. A current meter would show a great charging curent, but without seeing the 32-35V that the batteries were getting you couldn't tell how bad things were. We were comming out of Death Valley just about sunset and noticed "smells", turns out the batteries were boiled DRY!!! Fortunately had water to fill the batteries (over a gallon for each battery!) and rinse out the compartment. Adding water gave the system something to "work into" and allowed us to make the 6 hour drive home without further incident (sans replacing the batteries later).
One of my trucks has a digital voltmeter that I installed into the Tach opening, in the other truck I use my Garmin GPS that can not only run from 8-32 volts but has a voltmeter display (and can program a "low voltage" warning, too). Handy in alot of ways.
Jerbearyukon
I've had our two trucks for a combined total of 11 years, and the ONLY charging probem issues has ALWAYS been the damn Molex connector through the air ducting tin. Usually the wire corrodes on the inside of the tin, back in the plastic connector where it's darn difficult to see. When I've fixed mine I've used liberal amounts of De-ox compound (basically just grease) to help protect the bare wire, the crimp, and the actual connector junction from corrosion. Once done properly it's probably good for many years, but without corrosion protection it is a problem waiting to happen.
Because of that connector failure (and the fact that even though I knew to check it, I was too lazy to do so) it once caused the alternator rotor to fry, requireing a complete alternator replacement (can you say HUNDREDS of dollars?!). Learned my lesson the hard way. However, now with the voltmeters to keep tabs on things I've never been stranded nor caused more serious damage than just getting the connection fixed.
Jerbearyukon
okie dokie I will check the alternator side - I have re-dne the otherside.
So last night it was in lightning bolt mode - NOT CHARGING - This morning a fairy must have jumped in ahead of me adn the fairy must be a wrench. Barely started and it finally caught and started up. Bingo NO LIGHT...and charging at 27.9 volts.....WIERD
Jer Bear
Jer Bear
Twin Pinzies
Jerbearyukon
