fan balancing
Posted: Sun Mar 30, 2008 11:50 pm
I am going to have engine work done, is it worth the money to have the fan balanced as well?
Morris
fan balancing
Posted: Tue Apr 01, 2008 8:45 pm
by Pinz Enthusiast
Morris,
Deffinately do it, give Scot at EI a call I asked if he was going to do it and he said he would check into it, I had mine done by Jake Rabey and it works great, but as you can tell from the EFI posts it will take a melinium to get it done, took over 4 1/2 months to get mine back, but it does almost compleatly stop the vibration at the engine, another step is to have the front drive shaft balanced too, Jim L. and I couldnt belive how smooth my truck now runs.
Posted: Tue Apr 01, 2008 9:53 pm
by Erik712m
Yes, If Scott doesn't do it. you should be able to get ballanced locally most big air exchanges, towers have there fans ballanced just before install to increase the life of the shaft i had mine done here for around a $100 money well spent. Also driveline ballancing is nice but you better have a competent and honest shop do the ballancing or it well cost you more in the long run. and not just any one can ballance the shaft you have to have yokes made and that isn't cheap close to $700.
fan balancing
Posted: Tue Apr 01, 2008 11:01 pm
Thanks guys, that sounds really positive.
Morris
Posted: Wed Apr 02, 2008 8:28 am
by MASSIVE PINZ
We can generally turn a Pinz fan around in 2-3 days now.
The differences are huge after we complete our balance service on the fans.
fan balancing
Posted: Wed Apr 02, 2008 7:20 pm
Thanks Jake,
That is good to know, about the short turn around time. I was going to buy another fan just to avoid the 6 week delay and not being able to drive the pinz.
Morris
Posted: Thu Apr 03, 2008 7:49 pm
by pinzinator
Jake, how much do you charge for your fan balancing service? I may just send my fan in when I get the alternator rebuilt.
Posted: Fri Apr 04, 2008 8:53 am
by MASSIVE PINZ
The service is typically 90.00, BUT some fans are easier to balance and I charge 65.0 for those. We never know till I get the fan in the machine.
Posted: Sun May 04, 2008 9:29 pm
by Ken A
I just had my fan balanced for $40 (based on time spent) by a local engine rebuilder and it was done the same day.
It definitely cut down on the amount of vibration I could feel. Now I hope that it will cut down how often I have to retighten the carb screws
Getting the fan off was the only hassle; it did not come off willingly.
Ken A.
