Checking Gear oil levels
Posted: Wed May 28, 2008 8:04 pm
Hello everybody!
I am getting ready to check my gear oil levels in preparation for an off road trip. I discovered that the manual only has directions for changing the oils, not checking them. How do I check to see if the levels are correct? Do I just top them off? What is the recommended procedure? Start at the front and work back? Where can I expect the greatest problems?
Also do you all check these levels while on a lift or is it realistic to think I can do this on a creeper in the driveway?
What size allen wrench should I use?
Anything else I ought to think about before tearing into this? I know it's GL-4 for the tranny and GL-5 everywhere else.
Thanks!
Timothy
Thanks!
Timothy
