Question for those who have changed to LED's
Posted: Sun Jun 08, 2008 12:22 pm
Last Fall, I changed out my brake lights and added some small multi-volt LED turn indicators on the side at the rear (Outside of the bumber bracket on the side). I changed to an electronic flasher unit at the same time as I figured there wouldn't be enough current to turn over the old mechanical relay (...and there wasn't). That install worked great!
I liked the lights so much, that I bought some more to insert inside of the front turn signal housings. I figured that it would still look nice and clean, but I could switch out the bulbs for this epoxy-potted unit and life would be good. I did the install and "life was good"...or so I thought...I figured it would be a pretty straightforward install (forgetting that they never are!).
I guess there is not enough current draw on the system now.
Do I need to add a relay into the mix somewhere?
Sorry...it may seem like a dumb question, but I am "auto-electric challenged"
