Installed EI's High Clearance Muffler-PICS
Posted: Sat Jul 12, 2008 1:55 pm
Installed the muffler I ordered from Expedition Imports today. It is much higher clearance than the OEM. Fit was pretty decent.
The tail pipe end was a little "odd". The mounting bar they welded on has 2 studs welded onto it. Mine may have been a Friday run. The one end had the stud nicely ground and the bar itself was rounded off. The other end was just a flat square cut with a bolt tack welded in.
The kit does NOT include new nuts and bolts. Made a run to the hardware store, no biggie. Then I discovered the studs they welded on ARE NOT METRIC. Great, another run to the store. I think the design would be better with just holes drilled through the mounting piece. That's how the OEM was mounted.
The muffler itself seems to be made of very thick steel. Has a Mercedes logo on it.
It is MUCH louder than the OEM. I still need to run an exhaust pipe, but it has a ricer-racer fart can sound right now. I was hoping it would be quieter, especially since I could shove my finger through the side of my OEM one. I hope the back pressure is sufficient.
Still not sure how I want to run the exhaust pipe. Any suggestions are welcome.
