wood side rail dimensions, drawing?
Posted: Sat Jul 12, 2008 6:06 pm
by ka
i thought i'd make some nice hardwood side rails for this 710m. the ones on it are redwood and too soft to torque down tight. isn't there a drawing out there somewhere?
RE: Rails
Posted: Sat Jul 12, 2008 8:08 pm
by Thomas-E
You can go to the Yahoo Pinzgauer Site....
http://f1.grp.yahoofs.com/v1/kFN5SCpCYI ... nsions.jpg
Listed under files.
Posted: Sat Jul 12, 2008 9:10 pm
by russ
Check the thread "Tried to make rub rails from Trex boards". I wrote up how to drill the holes correctly. I recommend using Trex or other composite material as it is very weather resistant.
The drilling method works for whatever you are using though. The drawing posted does not show the recess for the nut and washer that holds the rail to the body. It also does not show the shallow recess on the other side required to allow the rail to be flush to the body.
If you have an existing piece of rail it will help.
Posted: Sun Jul 13, 2008 12:11 am
by ka
man, i love this forum. i put a question out and the full blown disertation returns! thanks yall...
Posted: Sun Jul 13, 2008 3:21 pm
by Pinz Enthusiast
I made some from redwood a few months back, I know it's a softer wood, but at my local home depot it was the only lumber I could get in a long enough lenght and hey the cost was just right, only $18.00 each and some time with my table saw and router, I did make mine a bit beefier and like the look over the stock size.
Posted: Sun Jul 13, 2008 4:04 pm
by Erik712m
Eric, Hi can you post a close up of the beefer rub rail i'm think it would be nice with the wider tires.
Posted: Sun Jul 13, 2008 4:39 pm
by ka
well mine are redwood and that's why i'm wanting to replace them. way to soft to screw down tight and i have to be careful about touching them casually so i don't get splinters.
Posted: Sun Jul 13, 2008 11:06 pm
by Douwe
I didn't want to spend too much time or money on my new rub rails so I made them out of pressure treated wood and haven't painted them yet.
I didn't like the look of Trex in the store. I saw a board with a chunk taken out of it and it make Trex look kind of brittle. I think that wood deals better with being scraped against a rock than Trex. But what do I know.
My preferred rub rails would be make out of metal though, probably U-channel or tubular like Mike's as shown in the referenced thread.
Oh wait, you asked about dimensions. I just guestimated based on the remaining pieces of the one's I replaced, It really doesn't matter that much.
Posted: Mon Jul 14, 2008 12:02 am
by McCall Pinz
Don't forget to use stainless fasteners to put it back together
Posted: Mon Jul 14, 2008 12:22 am
by ka
i use stainless 316 at least.
i just discovered via michael712m that someone in az is making rub rails of steel that stand off from the body aways and are part of a nice rear bumper. so now i'm thinking more along that vein. maybe i'll design something stout of aluminum. should be simple.
rub rails
Posted: Mon Jul 14, 2008 2:49 am
I made mine from 2 inch by 1.5 inch channel iron. I used the old wood for bolt hole pattern and used .25 inch washers to stand them off the body.
Painted them to match the OD color. Trimmed the ends like the old wood to avoid sharp ends on the metal.
Morris
710M, M416 trailer
Posted: Mon Jul 14, 2008 9:39 am
by andy
ka, that might be Tim. He made a set for my 710 that I think are very nice. I think he did Mike Nims also. You might try a pm to Mike to get in touch with Tim.
I would refer you to the SWPA website, there are pictures in the classified section, but it appears to be down at the moment also.
Andy
Posted: Mon Jul 14, 2008 11:16 am
by mjnims
Yeah, I am going to drop a set of rails along with some other armor in UT on my way home from the RMP treffen. Tim has built quite a few sets of side rails and I believe everyone has been happy with them. I put them to the test on many occassions and they work just fine.
Hre is my two trucks with them on it. The trucks look a little different now with the new stuff on them, just to lazy to go out and take a new picture.
Posted: Mon Jul 14, 2008 7:21 pm
by ka
yes! that's what mike described to me today. definitely a thoughtful design. i need.
