My Pinz is listing to starboard...
Posted: Tue Jul 22, 2008 1:57 pm
by hrafn
My 710K is listing to starboard (passenger side) by about 3 cm. Is it time
for new front springs or should I be looking at something else first?
Posted: Tue Jul 22, 2008 3:57 pm
Usually it's the other way around due to a wider seat area for the driver :P Yes the spring is worn, always replace in sets to avoid pulling while braking or overdipping in turns :wink:
Springs are pricey, but I love the ride since I replaced my fronts a little over a year ago 8)
Posted: Tue Jul 22, 2008 4:50 pm
by Twin Pinzies
Did you check your spring cups? It's not obvious when they break because they merely allow the spring to become less tensioned and therefore allow the body to "sag/list" to the side with the broken spring cup. I drove mine around for days before I looked at the rear springs and noticed that one was LONGER than the other!
Posted: Fri Jul 25, 2008 12:20 pm
by pinzinator
Jim, do you recommend OEM springs when replacing those in front or is there an aftermarket brand that works as well? I heard that the springs off of a BMW 740i work in the rear.
Posted: Fri Jul 25, 2008 12:59 pm
by rubicon4wheeler
If it's just a matter of stock springs sagging over time and under the weight of a bumper, winch, etc, then perhaps we can find a coil spacer that will fit our coil buckets and bring the front end up an inch or so?
Posted: Fri Jul 25, 2008 1:29 pm
by M Wehrman
A spacer (if available) would raise the truck,but you would still be limited on travel----spring bind.
I had springs made by a company in Kansas city,MO a couple of years ago. Price was 1/2 of oem,not progressive but rode well. In conversation he said he made a set for a 710 ft and rear for a softer ride. he keeps everything on computer including the ones for my 712. I purchased 5 sets to get a better deal,3 on our club members trucks,my own,and one to our boards home inspector. Name witheld to protect the innocent :lol:
I will try to find the spring company's name and post it.
Mark
Posted: Fri Jul 25, 2008 1:43 pm
by M Wehrman
Coil Spring Specialists
Kansas City ,MO
1-785-437-2025
As far as listing to starboard,could that be too many water crossings? :lol:
Mark
