valve adjustment tips ?
Posted: Sun Aug 03, 2008 11:50 am
by norcal pinz
hi can somebody give me some tips on valve adjustment what is the proper clearance ? thank you
Posted: Mon Aug 04, 2008 1:13 pm
by norcal pinz
i looked in the book and i have done this before but cant find the page that tells me what to set the valves at how often do you guys adjust your valves? in the pinz
Posted: Mon Aug 04, 2008 1:42 pm
.2mm or .0078" for all valves (adjust cold)
Posted: Mon Aug 04, 2008 1:51 pm
by norcal pinz
thanks jim do you happen to know the points gap and plug gap as well
Posted: Mon Aug 04, 2008 3:37 pm
by pinzinator
Pistons in cylinders 2 and 3 are at TDC at the same time, and so are pistons 1 and 4. Determine which cylinder is at the end of the exhaust stroke and set those two valves.
Posted: Tue Aug 05, 2008 3:39 pm
by norcal pinz
my feeler guage doesent have 2mm or.0078 i dont get it could it be
.007/.178 mm
or .008/.203 mm
or .009/229 mm sorry if this is confusing
Posted: Tue Aug 05, 2008 5:05 pm
by milesdzyn
Norcal, go with the .008/.203 mm feeler and you'll be good to go. Use the feeler to do the adjustment and recheck the gap after tightening down the nuts, as they may get off while you tighten them. Check them again after a couple runs.
Miles
