Horn Wire
Posted: Fri Aug 08, 2008 1:08 pm
by LibTimothy
Hello All.
My horn wire is shorted somewhere between the button and the bottom of the steering column. I can't see how to replace it. Any ideas? Anyone done this before?
Many Thanks!
Timothy
Posted: Fri Aug 08, 2008 1:22 pm
by Kirby
Take the old one out......put the new one in.......
Sorry
I just couldn't resist....
I have had good luck in the past getting to both ends of a wire and splicing a new length on (by soldering) keeping it real small and tight - and pulling through slowly and carefully .. .maybe with a little dielectric grease...? I have not done this on the pinz - but on a old trailer that was wired inside a closed frame rail... it worked good
Posted: Fri Aug 08, 2008 1:24 pm
by michaelh712
Yes, been there, done that; not fun.
I tried feeding a new wire from the top down, but it kept getting stuck. I was able to feed a thin wire up from the bottom, then attach (solder) the new wire to that and pull through the bottom.
good luck!
Posted: Fri Aug 08, 2008 1:43 pm
by M Wehrman
The wire goes thru a plate on the bottom of the steering gear,and a tube is installed in it so lube won't leal out. Top down would seem impossible as the chances of hitting the tube would be frustrating at best. Perhaps a length of heavy fishing line or weed wacker line from the bottom would be a thought as it is a tight turn into the gear. OR,loosen the box from the floor pan ,remove the pinch bolt under the dash and lift it up a bit to get a better shot with a wire. Good luck.
Mark
Posted: Tue Aug 12, 2008 8:46 am
by STPPINZ
I did it with the steering colum on my work bench. Pretty easy that way.
Posted: Tue Aug 12, 2008 7:48 pm
by Foz
I slipped drinking straws sections over the wire - this covered the section of wire with scuffed insulation coating so it stopped shorting out and sounding the horn whenever it touched the side of the column - this solved the problem for me - YMMV
Posted: Wed Aug 13, 2008 8:48 am
by LibTimothy
Foz,
You did this from the top down? From the horn button? How many straws did you use? This sounds like an interesting way to fix this.
Timothy
Posted: Wed Aug 13, 2008 9:04 am
by Profpinz
I agree... a nice bit of "lateral thinking"!
What do you do ----------
Posted: Wed Aug 13, 2008 11:35 am
by ABSOLUTSECURITY
What do you do if the straws wear out?????????????
Sorry just a thought!!!!!!!!
Glynn
Posted: Fri Aug 15, 2008 8:38 pm
by Foz
I don't remember if I cut one straw to make it fit or used more than straw.. but get a bright light and look inside - you can figure it out.
FWIW I doubt it will wear out in my life time - I reckon the original problem arose from some prior pokin' in the hole and fiddlin' around with the wires. I have no plans to do any of that - so I hope the fix is perm.. if not, I sure as heck didn't lose anything.
