Need to replace timing cover gasket, need advice
Posted: Sat Aug 16, 2008 10:47 pm
by todds112
Leaking oil pretty good. I'm pretty sure it's coming from the timing cover.
Should I replace the rear main seal while I'm in there?
I found some pics on the Yahoo forum that are pretty helpful, but these 2 confuse me.
Never heard of "wetting" a gasket.
This one might be more than I want to try myself.
Any special tools needed?
Posted: Sat Aug 16, 2008 11:17 pm
Those are my images
I actually no longer use timing cover gaskets
instead, I use Loctite anerobic sealer, and yes, do replace the rear main seal
BTW, to wet the gasket, you merely put water on it and let it sit for a few min, but be careful because they can tear easily and you still must use shelacking compound on the engine side only.
Posted: Sat Aug 16, 2008 11:31 pm
by todds112
What is the glass jar?
Posted: Sun Aug 17, 2008 1:04 am
Thats not a glass jar, it is the bottom half of a Solo plastic cup used as a seal guide to prevent seal damage during fitting
You must pack the back of the seal with vasaline or transjel and fit the cup to the crankshaft. After you slide the timing cover with the seal into place, you remove the cup, tighten the timing cover bolts and install the flywheel and clutch
Posted: Sun Aug 17, 2008 2:14 pm
by todds112
Jim LaGuardia wrote:Thats not a glass jar, it is the bottom half of a Solo plastic cup used as a seal guide to prevent seal damage during fitting
Ah, that makes sense. Thanks. Greats pics too, very helpful.
