900.4230 crush washers
Posted: Mon Sep 29, 2008 9:23 am
by K31
The parts manual refers in many places to these crush washers for the oil drain plugs, the fuel tank drain plug, the transmission drain and filler and level check plugs, and others. If these are commercially available through a car parts store like NAPA, does anybody know of a part number? Also, some of the plugs themselves are looking a little rounded on the hex faces, and I would like to have a couple of spares. Are these readily available through any of our sources?
Posted: Mon Sep 29, 2008 9:48 am
by Erik712m
Drain/Fill plugs
Posted: Mon Sep 29, 2008 12:15 pm
by Thomas-E
EI has both fill (steel) and drain (brass with magnet) plugs.
Napa #704-1364 Copper ring fits these plugs.
NOTE: fill plugs are steel and should be installed with anti-seize on the threads!
Don't overtorque, you may strip out the case's aluminum threads and it may be nearly impossible to remove the plugs. :cry:
I use 15-18 ft.lbs (180-200 Inch-lbs) no leaks and not a big fight to get out. :)
Tip..
Tightening the soft copper washers hardens them, thats why you should always use new ones or anneal the old ones to make them soft again!
Thomas E. 712M
Sonora, CA
crush washers
Posted: Wed Oct 01, 2008 2:26 pm
by K31
Thanks for the great info, guys!
Posted: Wed Oct 01, 2008 3:32 pm
by todds112
I just back from NAPA, bought all of them they had for future use.
