Changing the hub oil without making a mess
Has anyone got any tips on how to change the wheel hub oil without it going all over the wheels, tyres, ground etc.?
In Australia we have 2 litre plastic Ice-cream containers/tubs that are a perfect size to "clip" in place between the housing and the wheel rim.
The cast strengthening ribs on the bottom of the housing grip the lip of the container while the container sits in place of the inside of the rib.
I'm sure SDP was involved in the design of this container as it couldn't be a better fit if you tried!
If you haven't got a similar size container available I'm sure you could cut or trim a slightly larger one down to fit
I usually tuck 6 containers in place, crack all the drain plugs, then go and have a cuppa while I'm waiting for the oil to drain!
http://www.ozpinz.com
Peter,Profpinz wrote:In Australia we have 2 litre plastic Ice-cream containers/tubs that are a perfect size to "clip" in place between the housing and the wheel rim
Guess ice-cream has a horrible taste when you re-use those containers after changing hub oil!!
Just kidding ...
Ugo
710k & 716k in Torino, Italy
Ugo:
Pinzgauer hub-oil flavoured icecream ..... could be lovely!
After all, anything "Pinzgauer" has to have something going for it!
Pinzinator:
I'II endeavour to get you a pic at the weekend!
Pinzinator:
