webasto heater
Posted: Tue Oct 14, 2008 8:15 pm
Generally speaking, what is the consumption rate of a Webasto heater, since the unit is hooked up to the petrol tank?
Morris
Posted: Tue Oct 14, 2008 11:11 pm
by Profpinz
I think from memory, the 3500 uses just under 1/2 litre per hour on maximium.
Posted: Wed Nov 12, 2008 2:23 am
by ka
is the webasto the best heater for a 710m? what are the installation considerations/problems? my feet are starting to get cold around here and this thing has no heat exchanger.
Posted: Wed Nov 12, 2008 2:49 pm
by Jerbearyukon
I have the 3500 , but mine int th ek model. Dennis rigged mine up and it's awesome. Lots of heat and I have a damper to put it up front or in the back.
I will post some pics after I ge the crank pulley back on
Jer Bear
Posted: Wed Nov 12, 2008 7:18 pm
by ka
jer - that sounds like what i need. and yeah, any pix you could upload would be awesome. i'm planning on doing the job myself and could use plenty of data.
webasto heater
Posted: Thu Nov 13, 2008 1:05 pm
Dennis put in the 2000 for me. Works great, doesn't get that cold here like in the Yukon so I didn't need the 3500.
The consumption is about .12L per hour. Not going to affect my petrol use very much so the milage I am getting now, after the rebuild of the carbs, is not going to cause me difficulty.
Morris
Posted: Thu Nov 13, 2008 1:19 pm
by ka
krick3tt - what's are you doing to the carbs? mods, or just rebuild to spec?
webasto heater
Posted: Thu Nov 13, 2008 5:12 pm
ka,
I had Dennis at Linden do the rebuild on the carbs. I bought the rebuild parts from Scott at EI and gave the job to Dennis. He also rebuilt the dissy with the parts that I got from EI.
I had trouble with the engine rebuild (that is a whole other story) and with the donor engine, that Dennis put in to get me home, I got an average 15.4 mpg. This with a fully loaded 710 and an M416 trailer towed behind me.
I think that is very good milage for a 1650 mile trip with a 2.2L engine considering the mountains I went over.
Happy trails,
Morris
Posted: Fri Nov 14, 2008 5:49 am
by Scooter
I have the 2000 in my truck. Dennis was a big help in getting it in over the phone and thru e-mail. Here is what it looks like. I made the mounting brackets myself. I now have a tube that directs the heat into the back thru the wall that can be removed if needed for heat in the front. I did not add a vent for fresh air, figured it would not make a difference. Works great for here in Wisconsin.
Scooter
Posted: Sun Nov 23, 2008 2:01 am
by Profpinz
This my install of a 3500 Webasto....along the same lines as Scooter's setup.
Posted: Mon Nov 24, 2008 12:55 am
by Jerbearyukon
I will take pics of mine tomorrow for you guys. It was installed at Linden Engenerring by Dennis and the gang. I am real happy with it and the weather up here is COLD.
It's nice to cause the flapper can direct the heat for and aft and a mix if you want.
Jer Bear
